Black Hole Vu+ Duo 2.1.6
You cannot mix images versions in Meoboot.
I don't understand, because through meoboot I can chose between flash (= 2.1.3 installed), Meoboot installed 2.1.4 or Meoboot installed 2.1.5 and all three work fine.
Why does the installed 2.1.6 not boot, Imho I'am not mixing but installing multiboot versions?
The rear mounted usb works as flash.
Installing image in meoboot as with versions 2.1.4 and 2.1.5, image doesn't boot at all on my Vu+ Duo
My "flash" is an external 4GB USB stick, as per instructions in this forum
So I rebooted in 2.1.5
Like Shiro said; "You must have same version in flash." First download new BH 2.1.6 and run it from flash, then activate Meoboot, then download again BH 2.1.6 and run it from Usb or HDD within Meoboot.
Like you said, instructions are on the forum....working everytime. Only problem is that you have to be careful which skin to use, not all are working.
Black Hole 2.1.6
What is new:
  • Support for Picons in channel list
  • New Skin Matrix MX HQ7
  • Add vuplus-tuner-turbo drivers
  • update drivers
    20150302
    - Fix DVB-T tuner detection in new E2 frontend
    - Fix misc bugs.
  • update drivers
    20150317
    - Support new Gstreamer sink interface(OE update will follow)
  • update proxy drivers and utils
    20150318
    - Fix resolution problem when 720P skin is in use
  • update drivers
    20150403
    - Fix problem in new Gstreamer interface
  • update drivers
    20150406(duo, solo, uno, ultimo)
    - Support satip(OE update will follow. Other models are already supported)
  • update drivers 20150511
    - Fix tuner status information
    - Fix loop through(solose v2)
    - Fix Scart(duo2)
  • [hbbtv] support gstreamer-1.0 (1.5.4)
  • Add Cache / CacheEX button
  • Implement gpixmap scale function
  • Add support for picons by name
  • [Animationsetup] change default to simple fade
  • Update languages: Italian, Norwegian
  • fix Dual DVB-T2/C automatic scan problem
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Man
If your box is not genuine... it's normal that your box don't work ... so not bother about these fu***ng "issues" here.
My box is genuine and has been working perfectly fine for over 16 months until the image update yesterday, now all c lines gone - can only watch freeview, as a friend said, dont try and fix it if not broken!
Read our board rules, no support for illegal stuff here.!
You are banned for a week!
Many thanks a good read,I tend to think like your mate
For further explanation,
after installing 2.1.3 in flash I extended-flash as per forum instruction. Started meoboot and after that installed version 2.1.4 as well as 2.1.5 in this extended flash, only under meoboot. All three versions boot and run like charme.
Only this 2.1.6. version doesmn't boot after installinig under meoboot in the extended flash.
So I doent understand the difference between 2.1.6 and 2.1.4 resp. 2.1.5
Any clue what so ever?
I recalled my previous working methode:
As my flash is extended in /universe I rebooted through Meoboot into the original in flash installed version, which is 2.1.3
After that I open meoboot and install the 2.1.6.1 release which takes about 5 minutes. Original config settings are imported during installation.
The result is that I can now boot through meoboot into version 2.1.6.1 without having to install this version in flash as well as in meoboot and with the possibility to rollback to previous versions. This makes updates very easy and without the risk of a lot of work updating my Vu+ Duo
The difference between installed image in flash and one on USB
with Meoboot is that you continue to use drivers and kernel from image in flash and not from image on USB,Even when you use USB image you using kernel and drivers from flash image.
So if you have BH 2.1.3 in flash with old drivers and you use BH 2.1.6.1 on USB with new drivers you are not using this new drivers but old ones.
Open Multiboot is a better choice for Multiboot.
Each image uses its own drivers and its own kernel.
Thanks for this advice Matrix 10. This explanes things aren't optimal, so I'll try the open multiboot as suggested. Found clear instructions on openpli forum, formating usb, installing open multiboot and then installing new image.
Thans for BH team this great image 2.1.6. and 2.1.7
I have a problem after intallation of 2.1.7. My CI modul does not work. İt says in the common interfase menu
cam loader then no module found.
Someone help me solving my problem. Thanks,
Report it to Vu+ (www.vuplus.com) with all details about your hardware.
Hi Everyone i installed 2.1.6 for my genuine vu+ duo but i can not watch my iptv anymore, could you pls advise me what to do?
Many Thanks
