Black Hole Vu+ Duo v. 2.0.4
Hola a tod@s, he instalado esta imagen en y tengo un problema, no tengo forma de que me funcione el VOLAR HD PRO ni el VOLAR BLACK
En principio instalo la imagen y todo ok, luego al cabo de unas horas los TDT empiezan a pixelarse y al final dejo de verlos incluso me desaparece el sintonizador TDT quedando los otros dos del vu duo, a ver si alguien me puede ayudar a solucionarlo gracias.
i have 2.0.4 blackhole image installed but the channel to channel zap is slow around 6 secs to change can i speed it up ?
regards
skybot1.
regards
skybot1.
I think yes becouse speed change chanell on linux boxes is around 1 sec..
Try instal all from begined [ last version image BH 2.0.5 b ] put to image good seting list and try on FTA chanell your zaping mast be around 1 sec.
Ofcourse you have posibility send new setting and look to setup satelite on 2.0.4 but i think best way is made all from begined on new image. In this way you will be have fixed your problem and new image on box.
Hello, I'm new to the site and beginner, I have wanted to know a little something.
I have 1.6.4 installed on my system VU +, if I install version 2.0.4, I configured in my VU + subscription will disappear? Will I keep my favorites, settings, subscriptions, etc ...
with version 1.6.4, I have problems with network drives is it better with 2.0.4?
To backup my VU + I Dreamset is it good?
Thank you to all
Thank you to all
Before you gain a week ban, read our Board rules. You are warned.
