Black Hole Vu+ Duo v.2.0.8
great job as usuall, could it be possible in future releases to download different plugins at same time?
Black Hole 2.0.8​
What is new:​
  • New Vu+ drivers 16 december 2013
  • New Skin MX SkyLine By Matrix10
  • New Bootlogo IOS 7 Style by mikark
  • Support wmv, wma, asf media file (duo, solo and uno have to be enabled in BhSpeedUp)
  • Update OpenWebIf
  • BhEpgPanel: Change internal openepg default channel to Nat Geo
  • Update languages fr, no, sv
  • Add Audio Effect Plugin
  • Transcoding : support multiple encoders
  • Transcoding : support resolution setting , and advanced setup
  • A/V settings : update.
    - add "AAC downmix" setup
    - fix entry name, Dolby Digital downmix -> Dolby Digital / DTS downmix
  • gstreamer plugins updated:
    - added support for mms protocol.
    - added patch related on rtsp.
  • Transtreamproxy updated.
  • Support more video codecs in media playback.(OE 2.1 gstreamer)
  • Reduce First picture display time(zapping time improvement : duo2, solo2)
  • Support dual transcoding(duo2, Only 2nd transcoding is mutually exclusive with PIP)
  • Improve PCM playback(solo, duo, uno, ulitmo)
  • Support 3D surround (solo, duo, solo2, duo2)
  • Support AVL(automatic volume leveler)(duo2, solo2)
  • Support more proc entries to control duo2 transcoding.(Plugin will follow)
  • Improve temperature control of dual tuner when not in use(duo2, uno, ultimo)
  • FPGA update in solo2(done automatically in the first bootup after installation)
  • Fix EOS deteciton in media(PCM) & TS playback
  • Support AAC passthrough
  • Remove unnecessary debug messages(duo2)
01-bootlogo-jpg.13970
shot3-jpg.13972
shot4-jpg.13973
shot5-jpg.13974
shot7-jpg.13975
shot11-jpg.13976
shot12-jpg.13977
shot13-jpg.13978
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
I would love to update to 2.0.8. However in trying to Backup from 2.0.7 my personal settings the Personal Settings Backup Program crashes when at the plugin folders. Can anyone figure out what the problem is? Seems to mention a plugin.py file in the crash but in checking I don't think it was there in the first place. But I am a newbie so would appreciate some help. Report attached.
I have the same problem, i can not get it working when i select the keep settings function.
<!-- Cannot allocate memory -->
It seems that you have no free memory to work.
Add SWAP memory
or attempt to in BH speed UP to disable all unnecessary
and uninstall not used plugins etc
(blue>>Blue>>BH Speed Up)
Add SWAP memory
Bingo! I removed a plugin and disabled some unnecessary plugins. Then I was able to backup my Personal Settings. Thanks for your help!
