Black Hole Vu+ Duo2 2.1.2
Thank you very much! I love this Image, I love your work!
The best Image for my VU Duo2 , very beautiful and fast!
Thank you dev team !
hi, firstltly thanks for the new image. i have latest BH 2.1.2 image working but when i record one channel (usually fre*sat) and then want to watch something else on another transponder it wont let me until recording has stopped. i had same problem with BH 2.1.1 and reverted to earlier BH 2.1.0 all ok.
any ideas, possibly my settings?
What is your tuner configuration? How much cables do you have?
i have tuner a on fixed dish and tuner b on positioner & usuals, seems to work fine until i start recording
Black Hole 2.1.2​
"This release is dedicated to our friends that are sadly no longer with us Paolino and BigEd"​
What is new:
  • New skin MX Black Speed P
  • Duo2 drivers: fix dual DVB-T2/C tuner in changing mode
  • Update languages: es, no
  • Updated MediaTree (all dvb usb drivers)
  • Updated OpenWebIf
  • [hbbtv] Update and fix crash
  • [ScanSetup] Support TT3L10 automatic scan.
  • [TransCodingSetup] fix set config bug and wrong description.
  • [ScanSetup] dvb-t2 channel should be searched using scan app. & fix typo.
  • fix vuplus-blindscan-utils
  • Support dual DVB-T2/C Tuner automatic scan
  • Adjust bmem in duo/solo
    - To support 1080 FB
  • update drivers
    20141021
    - Support 1080 Framebuffer(duo/solo need kernel update)
    - Support Dual DVB-T2/C Tuner(uno, ultimo, duo2)
    - Support 4 vtuners(solose, vtuner is mutually exclusive with transcoding)
  • Added rtl8812au driver to the image (DWA.182 Rev A1 dongle works GREAT!)
  • Added isofs module in images with kernel 3.9.x are always compiled as a module (M)
  • [rt3070] added support for DWA-140 rev D1 (experimental)
  • Fix WOL problem in duo2
  • update drivers
    20140925(duo2, solo2, solose)
    - Fix HDMI problem in some AV receivers
    - Fix WOL problem(duo2)
    - Fix AGC/SNR display(SSH108)
    - Fix misc bugs.
  • [rtl8812au] changed drivers from Edimax to GitHub
  • [rtl8188eu] Updated driver to the last commit available
  • Update driver
    20140829(solo2, solose)
    - Fix transcoding problem(solo2, solose)
    - Optimize memory usage(solo2)
  • [vuplus-webmanual] fix incorrect output for solose.
  • update drivers
    20140808(duo2, solose, uno, ultimo)
    - Improve DVB-C/T(CXD1978) tuning performance
  • fix uno/ultimo harddisk detection
  • fix slow network
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
