Black Hole Vu+ Duo2 2.1.3
Black Hole 2.1.3 Universal Meoboot​
  • MeoBoot updated and now compatible with all major images
  • New Army skin DarkSky
  • New fade effect in osd
  • OpenWebIf updated and added Italian translation
  • Httpstream updated:
    - added chunked transfer support.
    - connect to TS stream in seperate thread.
    - add basic http authentication support.
    - add redirect and playlist support.
  • Elistbox: add setFont function (workaround for Full Hd skins)
  • media-tree rebuilded module list
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
i use the old bh 2.1.0, is there any easy way to upgrade it to the new 2.1.3 without installing all the apps and settings again?
Thanks for the excellent work.
I have flashed the BH 2.1.3 a couple of days ago. The flushing is smooth, every functions I tried are function well, particularlly, the EPG download is realy fast. The most significant improvement for me is the the recording. Now I can switch any free tuner when the recording is progressing. The issue was a headach problem in version 2.1.0
Thanks again for the Blackhole Team's excellent work.
how to make picon appear on menu
1-jpg.16561
Download picons and copy into USB folder "picon". If you want picons to be viewable on LCD panel you have to give a correct path in LCD4Linux plugin.
My Duo2 is using BH 2.1.0 and all is perfect except for Hbb Tv and Blind Scan as I suspect bugs in this image (2.1.0) that effect these two so I'm thinking of updating to BH 2.1.3 but I'm scared of all the work I would have to do although I have backed up everything via Dreambox edit and Dreamset + backed up my LCD4.config file. My duo2 controls 12 dishes + Terrestrial TV+Other and I am using the complicated Advanced setting found in Reception settings.
Now for the 4 questions I would like to know from you more experienced guys with the Duo 2.
1/ If I backed up my Duo 2 as what member Lefjomp is talking about and I reflashed the duo2 with BH 2.1.3 and restored all back will the duo 2 be the same as before I flashed it (all my settings,sats,DISEqc,etc + other). Remember my duo2 is set up to control a large collection of Dishes via DISEqC 1.2 and DISEqc 1.1.
2/ Before flashing with new image do I need to disconnect HDD (for Sat and Terrestrial TV recordings) and also the rear USB used for Picons only.
3/ After box is flashed with new image and say I reconnect the HDD and USB, remember the Existing Hard drive has recordings on it and so does the USB as that has plenty of picons in it what do I do to get the both to reconnect with the new image. (DO NOT WANT TO REFORMAT THEM AGAIN don't we) Do I just do a re-map or whatever so BH 2.1.3 will recognize both my devices.
4/ Any other matters I should remember/ do/ don't do before taking on this project of upgrading an image by backing up and restoring method.
guys when i think u cannot do any better u come out with this!!
OMG what an image - beautiful ........ thank you very very much
