Yep, the skin is the problem. Thanks angelofsky1980. I used the default skin, that still crash on transcode settings.
I downloaded MX reddiamond and then no crash. But then I do not get all the new settings for transcoding.
Are there any updated skins that has the new transcoding settings?
Or can I remove and re-install the default skin in any way?
Another somewhat strange thing is that if I go to Information / About then it shows version 2.0.7.3.
But I installed from the BlackHole-2.0.8-vuduo2_usb.zip downloaded from this site. And I get the new bootlogo for example. Is this correct ot have I ended up with a mixed version?
