Black Hole Vu+ Duo2 v.2.0.8
Thanks for 208... I downloaded and cannot get the Duo2 to update from 207.3. Did the usual copy Vuplus folder to my trusty Kingston usb stick root, inserted in front panel and after cold reboot the receiver bypasses the usb stick. Tried both rear ports with same results. Tried five other name brand usb sticks with same results. Some usb sticks have a led and they indicate that there is activity when the receiver is booted.
Your input would certainly be very much appreciated.
I never use Kingston for flash images.
Use older slower USB sticks.
Probably that you have yet another USB stick at home older one no name 2 to 4 Gb
but you have to push front button and disconnect all other USB sticks/devices etc
Thanks Matrix10, just tried again and it worked... still using the old Kingston and inserted in rear top port. Go figure... gremlins.
Thanks. I restored my settings afterwards and lost the nice new bootlogo.
how can I get it back, is there somewhere I can download it?
thanks again
Bootologo IOS 7 Style by mikark
Please, add channel list editor so we could delete or rename any program.
Many Thanks!
How do you think to edit hundreds if not thousands of channels
without computer editing . With your remote ??
To do this you need a whole day :D
But you can delete/remove ,move channels >>> press Menu button when you're in the channel list
THX for new img. I have problem, update ok... after no start...
testing second download and flashing..
edit - aleluja working :) ... hmmm, nice
