Black Hole Vu+ Solo 1.6.7 kernel 3.1.1 beta2
Hello peeps,
Just installed the bootloader first and then the image.
After set and done I installed the last driver from Sundtek with date december 8. After a restart it is saying there is a Dummy usb attached insteed of the Sundtek. So did I overlooked something and is the Sundtek not yet supported???.
Will wait for a answer before going back to a earlier version.
Hello peeps,
Verify when the loading script of Sundtek package is loaded: the script will be launched BEFORE E2 binary.
hello
at first thanks for the new release
when i use skin hd glass16 and then i push the blue button , the box crash ( green screen)
thanks for help and exuse for my bad english
hello
Use a skin certified to run into BH 1.6.7 image or newer.
After tonight's test
because I did not have time before.
:lamo:
I can only say.
I think this is a big improvement for VUsolo
image is very fast and stable as never before.
Of course, due to changes in the kernel
Some things have yet to tune.
But this image is certainly a big step forward for this nice box.
i was using this skin with BH 1.6.6 without problem
There is no difference in the coding of the blue panel
BH 1.6.6 and BH 1.6.7.
But Im sorry
I do not recommend this skin because the skin is not good for image.
Too heavy and slows down image and alters the stability of..
and certainly not good for normal VUsolo operation.
It uses its own python coding that might now conflicts with the new image.
It the mean time a put another image on the Solo and installed the Sundtek flawless, so I again installed the latest BH put still the sam issue.
But also when installing it also says different things when it normal does, so after a restart I tried the Autostart en Start scripts for the Sundtek but it says the sticks cannot be found.
I added a screenshot of the installation progress.
http://imageshack.us/photo/my-images/846/naamloosiq.jpg/
And by the way what do you mean with " the script will be launched before E2 binary"?.
By the way one other thing I always get stuck configuring a usbstick on BH for recording.
Untill now I always got it setup on a VTI image and after switching to BH the stick works normal without a problem right away.
But now I initialized it in BH and then mounted it on media/hdd but after a restart it gives me an error when trying to record.
So can someone please give me a correct way to set this up on BH :)??.
Thank you for new version of image. All of new version is better than previous :)
But, i have one question, maybe stupid but i am interested. I see that before instalation of BH 1.6.7. is necessary to upload CFE. Is it possible to install back some of previous version of BH image (1.6.6. or 1.6.5) after this upload of CFE, if it will be necessary (if some things will not work correct in new version 1.6.7 or simply if i like more previous version than this new)?
Thanks
Tested Yesterday. Perfect. Thanks BH team !
HDMI CEC worked perfect (all options: standby or wakeup from the 2 sides (TV & VUSOLO)). One remarq, the name in HDMI CECI is VU+DUO if you can change (like in BH1.6.6) to VUSOLO!
I will continue testing, I will report as soon as possible.
Thanks again.
Have you make movie folder on your stick ?
For the HDMI CEC device name, I found it ! sorry! It's in HDMI-CEC plugin setup, by default it's VU+DUO (I changed to VUSOLO). thanks!
Thanks
You can still use older versions after the CFE upgrade.
