Black Hole Vu+ Solo 1.7.0 Multiboot Full Backup
whit this vesion multiboot problem that was on vu solo is solved
thx
It can be hoped that the Web browser plug-in for the solo model on the image to be?
I just installed the new image and I have not noticed any improvement on the previous, the only difference is that once the Vu + Solo is on standby and I press the power button on the remote takes a few seconds more than the previous version to show image the TV.
hi there
now i am using BH 1.6.5 if i upgrade to 1.7 is it possible to restore BH personal backup taken with 1.6.5 backup plugin?
hi there
No. BH Personal Backup between two images with different kernel is not compatible.
You have two ways:
1. install latest BH and reinstall plugins you need
2. use Software Manager to take backup of your plugins and settings and restore it to new image.
You have two ways:
thx
does Backup System Settings in Software Management backup plugins too?
how should i know if all the plugins are compatible with new image?
thx
I haven't used any kind of backup system from one image to another because I use a very limited number of plugins ;) and I make the complete configuration when a new image has been released: it cost for me less time who use a backup tool :)
About Software Manager: I think you should configure the backup process to save your plugins but I cannot guarantee that they work on the new image :(
I use a very limited number of plugins too my main concern is forgetting some of the settings
any way thx angelofsky1980
i think i must install plugins one by one and test if they are compatible or not
I have a question about meoboot 1.0, as I understand the image installed on the multiboot must be usb.zip format, however I have nfi images and I want to install them, then how?
My friend, with MeoBoot 1.0 can be installed ONLY imges with latest 3.1.1 kernel and all are avaiable in USB formato (zip file)....
