Black Hole Vu+ Solo 1.7.4 Parallel Universes
One remark about red pannel (1 x Red): I try it yesterday without installing channels in the default universe and red pannel does apear when I press Red button once. So I restored my setting from backup and Red pannel works.
I
I mean "doesn't apear"
"I try it yesterday without installing channels in the default universe and red pannel does NOT apear when I press Red button once. So I restored my setting from backup and Red pannel works
One question please:
What about personnal backup and Image backup in the BH1.7.4: will the backup take all the universes or just the active one?
I Want in first thank all th BH team for the effort and want some help if it's possible.
after the installation reboot the screen stays black with the green led light but i saw that the light while installing the image become orange than red than orange again and finally blinking green ... but after that only black ! is there any soltion (i've VTI before the operation)
Thank you !
Thank you !
Did you flash the cfe before ? (This image BH1.7.4 is using new cfe for vusolo)
Thank you !
I assume you have updated the bootloader ?
I think it is better if you turn off power to begin the initial control image
The starting and electrical connection to the decoder box is turned off and the remote control turn it on manually
so grate job and tnx
Fantastic ! Great Work. Thanks to the whole the BH team.
I have an issue with 3g modem plugin: when I want to modify the profile (to use with the 3G modem: APN user, password, phone...), For the phone zone I can't enter the # caracter. I think it must be with touch 0 but there is no #.
Can someone test if there is a touch to have # caracter in phone zone.
Otherwise, can I have the file name where 3G modem configuration (APN, user, password, phone...) is stored in order to modify this file by telnet.
Thanks in advance.
Thanks for this awsome image !
Is there any chance to make army gradiant skin for this image ?
I thinks that skin is perfect because it is so simple and also it is transparent .
just need a channel number in the info bar to be the best forever :)
I think Army will publish updates for their skins ;)
hi all, can i use bh 1 7 4 (blackhole universe) only without installing the other universes (avalon, chaos and ghost) because i dont want to use the other universes.thanks in advance.
Sure. You don't need to use universe feature if you don't want.
thaks again for this great job.
how shall we proceed with the instalation of this awesome image. I mean shoul i insert the 8g usb before starting??
sorry for this elementary question.
