Black Hole Vu+ Solo 1.7.7
Hello comrades s:
First, give the Thanks for this new image.
The'm testing on my Vu + Solo, and I have a problem that I do not recognize my usb-tdt WinTV-ministick.
Please if you are so friendly you can tell me how I can fix it.
A greeting.
how to test hbbtv on vusolo bh 1.7.7?......if this option is included in this image.Thank you.
Vu+ has not included HbbTV support for Solo.
BH is based on official Vu+ Git & images and is aligned with them.
Hello comrades s:
A greeting.
I think will be solved with new USB DVB drivers under tests by BH Team.
Hi all,
I've upgraded my Solo box from 1.7.4 to 1.7.7, and I've noticed that picture quality is better in 1.7.4, especilally for displaying human faces. Reds are more saturated in 1.7.7.
I didn't tested 1.7.5 and 1.7.6.
Does someone noticed the same problem?
Your story abt HbbTV on VUsolo is totally wrong and not true.
When the HbbTV works well on VUsolo
Then VU + would not have any interest in that to not put inside the image
But this is not so
Test and let me know how it works ???
i tested it's work with vti 4.2 after added usb formated in rame
I know it can be made to work
But I wondered how it works for your testing.
In my testing, it works poorly
and not only that, but affect the operation of the whole image.
So I prefer without than with.
Hello all.I am new.I currently had the 1.6.7 version and i tried to flash with this new version. I am having problem because when when the Vu Solo starts to boot up , it does not progress.
Can soemone tell me what is wrong
Reformat your FAT32 USB stick and retry flash your box.
can someone correct my steps I am doing :
1) currently I have the 1.6.7 version and it works fine
2) i am downloading the CFE file and booting up the Vu Solo with it.As the indicator comes Green I am switching OFF the decoder
3) i am formatting the USB and download on the USB the 1.7.8
4) booting up the Vu Solo with the USB.As the indicator comes Green I am switching OFF the decoder
5) switch on the VU SOLO but remaining black screen
can someone explain me what I am doing wrong
Thanks for your patience
Well after step 4 you should remove the usb stick.
If all these steps doesn't work then may be you have a clone box.
If you're from Morocco be aware that there are lot of clone boxes on the market.
I suggest you to return it and buy a Vu+ Uno.
no my dear friend.me and my friend have bought it together but he managed to do it and I did not.it is a matter of time , that I have to wait for him to be available.so i am trying before he is available
