Black Hole Vu+ Solo 1.7.8
Hi frinends
I,m new on this forum, I try to instal,l for the first time, last version BH 1.7.8, but once finished and restart, nothing appear on my TV.
after several test, the only version that works is the 1.6.6 :(. of couse I have before installed the FCE file.
Can someone help me ? :notworthy:
Hi frinends
If you have upgraded CFE you can run recent images.... you can try to reflash CFE and retry flash image....
If this steps doesen't works ... the only thing you can do is to grab a serial debug output during flash CFE & image process and first boot ... and post here to try to solve the problem.
Thanks angelofsky1980,
Unfortunately I'm not expert on this, can you reply the procedure to recovery the info ?
First of all try to reflash CFE and Image ....
Dear angelofsky1980 ,
as said above, our VU SOLO is working fine with Version 1.6.7.so as you told us , we are transfering the CFE file as found in this initial post and afterwards we are booting up with the 1.7.8 image but the VU SOLO is remaining with a black image .
Thanks for your support
I will verify (again) tomorrow with Solo.
Hello Friends,
After installing latest version for VuSolo 1.7.8 i have only 1 problem, when i try to change iptv channels on list with left and right buttons on remote,
picture is stop for some time (10-20 sec. ) and then play again on same channel, if i change from the list with ok button then is switch to another channel without problem,
this problem is on new 1.7.8 version, previous version 1.7.7 is worked good, please repair these in next version of firmware
Hello Supporter Guys
I have a post on older image category ( 1.7.7 ) about WiFi USB Network. I Have 3 WiFi USB Network from 2 brands, 2x Linksys WUSB600 V2 and D-Link DWA110. All WiFi Networks worked fine before 1.7.0 Image but After Update to 1.7.7 Linksys not recognize with VU+ Solo and and D-Link sometimes missed and i still have problem too with 1.7.8. I need N Network ( linksys ) for maximum bandwidth. what can i do ?
Thank you , GREAT JOB.
On my VU+ duo everything works absolute perfect including HbbTV. Duo is running on BH w/o. any external memory extension on USB - stick and w/o. any parallel universe, - so far -.
On my VU+ solo in beginning after installation of BH 1.7.8 didn´t show HbbTV extension after pressing -blue- long.At that time memory was standard, w/o. external extension.
Then I decided to extend memory and installed also parallel universe, now HbbTV is available after pressing - blue - long. But: loading HbbTV is extremely slow and by this fact so far not recommended for use.
Presently I have installed an 8GB stick on the rear USB - port. The stick is splitted into 4000MB on /dev/sda1 and media/usb1, and 4000MB on /dev/sda2 and /universe . The parallel is Avalon.
Because I know from my duo how amazing BH 1.7.8 HbbTV can be, I´m very interested to improve 1.7.8 on my solo to make it also available for HbbTV.
Question: How can this be done? What went wrong on the solo?
