Black Hole Vu+ Solo 1.7.9
Can I use this Image on my Vu+ Solo? This morning I got him, but I need help to put Image in him. This is first time that I have Enigma 2 receiver. I want to use BlackHole, but my receiver isnt Vu+ Solo original, it is clone version.
And I only need put this on my flash memory and install via USB (front or rear) port?
Can I use TP Link 422G USB stick on front or rear port on this Image?
Thanks! :)
Best Regards!
No support for clones on this board!
thanks for image bh. could you put the clock back in the channel list the one were you press the curser down. thanks
It's a skin addon. Try different skins from BH Addon Server if there is one who had the clock, otherwise, ask in the Graphics sections if the clock can be re-added to skins.
probleme in vu+SOLO? when i use blackholeimagr 1.7. the receveiver block and i can't connect with remote controle i need to restart;
Hi everyone,
How can I disable/ enable the default plugins?
Thank you.
Is very easy by you mast go to blue panel/Bh seeting/Bh speedup and in this you mast only enable/disable plugins and made reboot box after this you will be no see plugins
model TP-LINK WN821N
v1 & v2 of your adapter uses CARL9170 driver (included into BH)
v3 uses ath9k_htc (included into BH)
v4 uses rtl8192cu (included into BH)
If you have problems, open a thread into Wifi Drivers sections and post "dmesg" output when you plug your wifi dongle to your box.
bongiorno ah tuuti: sono un ragazzo che piace imparare il sat oh un v+ solo e sto prendendo un po di confidenza pero sto vedendo che piano piano mi vicino ah diverse soluzioni gra zie al vostro contributo....
What about TP-Link model: 422G, will it work on this BH 1.7.9 Image? I will get it in next days, so I hope that it will works. Did anyone check this?
