Black Hole Vu+ Solo 2.0.2 Rev. A
You can try to flash your new Vu+Solo box ... if doesen't boot, upgrade Vu+Solo CFE and reflash the image.
In the Vu+ General section there is a thread about Vu+ clones read it carefully.
thanks a lot.
did you mean this thread? http://vuplus-community.net/board/threads/caution-vu-clone.4683/
(finding out clones by visual inspections)
now how to flash? after downloading the image what should i do?
and what is CFE and how to upgrade it?
sorry for too many questions.
thanks a lot.
CFE Upgrade for Solo box: http://www.vuplus-community.net/board/threads/vu-solo-boot-loader-updgrade.4358/
About flash your box:
1. download the image on your PC
2. unzip the image
3. put the "vuplus" folder obtained into a FAT32 formatted stick
4. put the usb stick on your box (rear or front)
5. turn on your box. It will blink orange/red when it flash the box. When the led blink green remove the usb stick and reboot your box
2. unzip the image
wow! thank you sooo much.
about that clone thread, can you give me its link? there's too many threads t
in Vu+ General section.
thank again.
You have already found the link.
thanks, i will try upgrade CFE, then flash this image.
if there was a problem or mistake i will ask your help again.
EDIT: will doing these steps show me if my solo box is clone/genuine instead of visual inspection?
sorry for my english
First of all see the Vu+ Clones thread and verify visually if you have a genuine box or not
hello
after installing this image, my box update channel list automatically
how can i stop this please ?
regards
Before ugrade BH 2.0.2 revc.C copie to Pc or somewere else timezone.xml from tuxbox, because in new C revision doesnt work timezone corectlie, after upgrade copied back
BH ver.2 and ver.1.7 have problem with network , when i watch my SAT TV some minutes, after that Ican't opening mediaplayer. Tuner freezing and stoped work. Only in ver.1.6 worked corectlie What I do wrong?
Hello! I think I find problem maker app-COOL TV . I have instaled BH 2.ver. without COOL TV and working fine yet.
Hello! Sometimes I get no picture but sound sometimes I see picture but no sound. Restarting GUI or Vu+ helps in this case? Any ideas? Thank you.
