Black Hole Vu+ Solo 2.1.0
Tuner usb avermedia volar hd prob (A835B) has a problem in vu+ solo when tunning, suddenly an error message appears (error in PAT), but if I made a manual search it works again until next error..
Maybe is a driver problem? it works good with solo2 and uno, and ultimo for example..
Try to use an external powered hub USB with Solo 1st generation box.
Ok there is a workaround to get teletext working for those that need it.
telnet into your box and then type the command
opkg update
and press enter.
Then type the command
opkg --force-overwrite upgrade
and press enter again.
When it has finished, reboot your box and teletext will be working.
Hi, thx for reply, but why it works without usb hub in old version like 2.0.9 and newer versions no?, also it fails sometimes in vu+ uno...from version 2.0.9.1 and above...
Can be a "problem" with USB ports who doesen't provide sufficient power to your USB device.
This can happen in a non predictive way ... I suggest to use always an external powered USB to minimize power problems.
Hey guys. Tried to install 2.1.0, but could not. Even 2.0.9. But 2.0.7 installation is ok. Box is vu solo mini from China. What should I do? Thanks.
I tried last day, still same problem, avermedia dvb-t starts working but after few zapping, eror message of PAT appears, or even mix frequencies, I zap to one channel and appears video of other channel...
Actually there is a dvb-t model that works ok, Vissionet, because I did detect some fails even with wintv ministick (hauppauge)
If you tune a channel and you see another channel ... seems there are some settings problems and the DVB USB device is not your first problem.
