Black Hole Vu+ Solo 2.1.1
i just updated to latest firmware, and black screen,,,,ye ye ye,,,banned for a week, for being sold a clone as a genuine box,,,,,gutted,,,,
Is the sattelite Turksat 4A added on this software.....?
And how can i add manuel a chanel on my Vu+ solo.
I can add parameter 12615 V
When i add Fec: 4800 , how do i this to search for the chanel.
good morning to all I have a problem I install the black hole 2.1.1 on cloud ibox mini vu but only after you have installed nn is the boot screen remains black thank goodness nn Bricca maybe something wrong with the decoder
I wonder if I can download the latest image VU Solo + directly via Box, I have an old picture that is already beginning to cause problems and the picture freezes very often, any advice?
hi,
i fleshed 2.1.1 on vu solo..
i have problems watching movies that i have on my shared cifs pc hdd...what happens is that i go to media player, i choose my movie from shared disk and i have black screen...if i press one or few times exit or something else i need to power off ... when i restart the box, i will do same things and movie will play...than after few hours i will choose different movie from same disk and will not work, black screen, sometimes i can hear the sound from movie, but no video...
after i will restart the movie will be shown...
and it happen that usb dvb-t key will not work...it stops sometimes when you are not wathing channel on dvb-t tuner...
i need to restart the box, to mke it work for few hours or maybe day or two...
i did fresh install i did disable some things like backup etc.. and enable support for wma and youtube...
i did not restore backup from old version 2.0.1...
i did restore my channel list...
i have a log, but i can't understand it...
i think that something is wrong with video , converter or something..
this is my second fresh install because i tough that i will solve problem refreshing it...
i'm reading that a lot of people have some problems with this version, i did try to update image, but after quite a lot of time that was displayed downloading it was 0 installed...
what else i can do?
thanks
by
kikan
thank tou
Black Hole 2.1.1​
By Black Hole
  • New skin MX SkyLine SE
  • Add new Crypto systems in OSD: Biss, Bulcrypt, Betacrypt, PowerVu (By Ev0)
  • Add parental control in Bh extra settings panel
  • HbbTV enabled by default for Duo2, Solo2, SoloSE, Ultimo
  • Removed mytube plugin (can be installed from BhSpeedUp)
By Vu+
Kernel:
  • Update Kernel 3.13.5(solo2, duo2, solose)
  • Update Kernel 3.9.6(duo, solo, uno, ultimo)
Drivers:
20140715(duo, solo, duo2, solo2, solose)
20140716(uno, ultimo)
  • - Support SoloSE
  • - Switch to Kernel 3.13.5 (solo2, duo2, solose)
  • - Switch to Kernel 3.9.6 (duo, solo, uno, ultimo)
  • - Fix sound drop in radio channel
  • - Improve PIP (solo2, duo2, solose, Needs E2 update)
  • - Allocate more memory to linux (duo2)
  • - Improve media playback
20140721
  • - Fix vfd problem
Misc:
  • Update r8192cu (4.0.2)
  • Update bridge-utils (1.4 -> 1.5)
  • Set sync PCR at PIP mode.
  • fix duo harddisk detection
  • [hbbtv] fix UI position
  • [hbbtv] upgraded to 'opera-hbbtv_0.2.bb'
  • disabled copy libs to sysroot
  • [hbbtv] reduce CPU usage
  • [hbbtv] fix ipc protocol
  • [hbbtv] fix flickering some channel.
  • support seeking the recorded video
  • lcd4linux: update to 4.1-r2
WARNING! DO NOT USE PERSONAL BACKUP FROM PREVIOUS BLACK HOLE IMAGES, AS THIS WILL MIX KERNELS AND LIBS CAUSING MANY MALFUNCTIONS.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
good job thanks blackhole but please i want to make this image with different bootlogo same as in 2.0.7 version any help please i cant got it in bootlogos here in forum
Hello
i have a vu+solo currently on BH 1.7.8
Can I update directly to BH 2.1.1 or do I have to update my kernel & bootloader?
cheers
thank you so much
  • - Support SoloSE
20140721
  • - Fix vfd problem
Misc:
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
[/QUOTE]
Black Hole 2.1.1​
By Black Hole
By Vu+
Kernel:
Drivers:
  • - Support SoloSE
20140721
  • - Fix vfd problem
Misc:
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
