Black Hole Vu+ Solo 2.1.3
1. I've no created swap
2. mountmanager works regularly
3. what updates?
1. from blue panel, swap manager, i can't create swap file, maybe it's my problem, previous versions 2.1.1 and 2.1.2 works
2. freezes here, ok only my problem in this case maybe!
3. menu / addons / bh upgrade -> freezes here with spinner when download bar is blocked
I have the same problem :(
All the problems you reported are because of flash and memory full.
Install a clean image and then install meoboot and install another 2.1.3 in meoboot.
Run the image in multiboot and setup a big swap. In this way you will solve all the problems.
difficult for me to talk english so i only give you crash reporti hope can help to resolv problem
<?xml version="1.0" encoding="utf-8"?>
<opendreambox>
<enigma2>
<crashdate>Sun Nov 16 17:14:19 2014</crashdate>
<compiledate>Nov 13 2014</compiledate>
<contactemail>crashlog</contactemail>
<skin>skin.xml</skin>
<sourcedate>2014-11-13</sourcedate>
<branch>master</branch>
<rev>a98ed72</rev>
<version>3.0.0</version>
</enigma2>
<image>
<dreamboxmodel>dm500hd</dreamboxmodel>
<kernelcmdline>bmem=156M ubi.mtd=0 root=ubi0:rootfs rootfstype=ubifs rw rootflags=sync</kernelcmdline>
<imageversion>
<![CDATA[
version=1000201411130943
</imageversion>
<imageissue>
<![CDATA[
BlackHole 2.1.3 %h
</imageissue>
</image>
<software>
<enigma2software>
<!-- Cannot allocate memory -->
</enigma2software>
<dreamboxsoftware>
</dreamboxsoftware>
<gstreamersoftware>
</gstreamersoftware>
</software>
<crashlogs>
<enigma2crashlog>
<![CDATA[
onts/nmsbd.ttf...OK (Display)
[FONT] adding font /usr/share/fonts/Army_Regular_L.ttf...OK (Regular)
[FONT] adding font /usr/share/fonts/Army_Bold_G.ttf...OK (RegularAA)
[FONT] adding font /usr/share/fonts/army-digital.ttf...OK (LCD)
[FONT] adding font /usr/share/fonts/goodtime.ttf...OK (OLED)
[FONT] adding font /usr/share/fonts/tuxtxt.ttf...OK (Console)
[FONT] adding font /usr/share/fonts/ae_AlMateen.ttf...OK (Replacement)
[FONT] adding font /usr/share/fonts/nmsbd.ttf...OK (Display)
[FONT] adding font /usr/share/fonts/nmsbd2.ttf...OK (oledRegular)
[FONT] adding font /usr/share/fonts/nmsbd.ttf...OK (oledDisplay)
[iInputDevices] getInputDevices <ERROR: ioctl(EVIOCGNAME): [Errno 25] Inappropriate ioctl for device >
cannot open /proc/stb/avs/0/input_choices
--> setting scaler_sharpness to: 0000000D
couldn't open /proc/stb/misc/12V_output
resolve: resolve ${datadir}/enigma2/keymap.xml
resolve: -> /usr/share/enigma2/keymap.xml
[ePopen] command: ip -o addr show dev eth0
setLCDBrightness 25
setLCDBrightness 127
resolve: resolve ${datadir}/keymaps/
resolve: -> /usr/share/keymaps/
Activating keymap: Keyboard English
[ePopen] command: loadkmap < /usr/share/keymaps/eng.kmap
Activating language French
language set to fr_FR
FIXME: request for unknown slot
[RemoteChannelStreamConverter] fallback to default translation for Remote channel stream converter
[RemoteChannelStreamConverter] fallback to default translation for Convert remote channel list for streaming
resolve: resolve ${datadir}/enigma2/setup.xml
resolve: -> /usr/share/enigma2/setup.xml
resolve: resolve ${libdir}
resolve: -> /usr/lib
[MeoBoot] set language to fr
[MeoBoot] fallback to default translation for E2 Light Multiboot
[audioselectionplus] set language to [fr]
<ZappingModeSelection> set zapping mode : mute
resolve: resolve ${sysconfdir}/enigma2/
resolve: -> /etc/enigma2/
--> setting contrast to: 00008000
--> setting saturation to: 00008000
--> setting hue to: 00008000
--> setting brightness to: 00008000
--> setting block_noise_reduction to: 00000000
--> setting mosquito_noise_reduction to: 00000000
--> setting digital_contour_removal to: 00000000
--> setting splitmode to: off
--> setting sharpness to: 00000000
--> setting auto_flesh to: 00000000
--> setting green_boost to: 00000000
--> setting blue_boost to: 00000000
--> setting dynamic_contrast to: 00000000
--> applying pep values
[AutoShutDown] set language to fr
[AutoShutDown] fallback to default Enigma2 Translation for Standby
[AutoShutDown] fallback to default Enigma2 Translation for Deepstandby
[AutoShutDown] fallback to default Enigma2 Translation for AutoShutDown Setup
remove DVI-PC because it does not exist.
hotplug on DVI
set Videomode DVI 1080i multi
set aspect, policy, policy2, wss 16:9 panscan letterbox auto
[*******] Started
restarting enigma dreambox
[CI_Assignment] activating ci configs:
[CI_Activate] FOUND 2 CI Slots
resolve: resolve ${sysconfdir}/enigma2/ci
resolve: -> /etc/enigma2/ci
[CI_Activate_Config_CI0] no config file found
[CI_Activate_Config_CI0] error parsing xml...
[CI_Activate_Config_CI1] no config file found
[CI_Activate_Config_CI1] error parsing xml...
starting BlackHoleapi handler
starting hotplug handler
It's now Sun Nov 16 17:13:48 2014
[timer.py] next activation: 1416154528 (in 99370 ms)
[timer.py] next activation: 1416154528 (in 99339 ms)
[AudioSelectionPlus] autostart checking
Looking for embedded skin
[AudioSelectionPlus] sessionstart
[CrossEPG_Auto] AutoStart Enabled
[CrossEPG_Auto] Schedule Disabled at Sun Nov 16 17:13:48 2014
[AutoShutDown] start....
port changed to DVI
mode changed to 1080i
default ('1080i', 'd\xc3\xa9faut')
preferedmodes ['720p', '576p', '480p', '576i', '480i', ('1080i', 'd\xc3\xa9faut')]
[EPGC] setCacheFile read/write epg data from/to '/hdd/epg.dat'
[EPGC] time updated.. start EPG Mainloop
before: 1
after: 1
not showing fine-tuning wizard, config variable doesn't exist
showtestcard is false
setValue 100
Setvolume: 100 100 (raw)
Setvolume: 0 0 (-1db)
[EPGC] 1040 events read from /hdd/epg.dat
[EPGC] start cleanloop
[EPGC] stop cleanloop
[EPGC] 238631 bytes for cache used
allocating new converter!
resolve: resolve ${datadir}/enigma2/%s/
resolve: -> /usr/share/enigma2/%s/
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
main thread is non-idle! display spinner!
RemovePopup, id = ZapError
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
reused converter!
playing service..
[AudioSelectionPlus] service info changed ...
not pauseable.
allocate channel.. 0400:0001
opening frontend 0
[eDVBCAService] new channel 0x1fba4a8!
(0)tune
RotorCmd ffffffff, lastRotorCmd ffffffff
prepare_sat System 0 Freq 11567500 Pol 1 SR 22000000 INV 2 FEC 4 orbpos 192 system 0 modulation 1 pilot 2, rolloff 0
tuning to 1817 mhz
OURSTATE: tuning
allocate Channel: res 0
[eDVBCIInterfaces] addPMTHandler 1:0:1:2136:400:1:C00000:0:0:0:
allocate demux
resolve: resolve ${sysconfdir}/scan_tp_valid_check.py
resolve: -> /etc/scan_tp_valid_check.py
[SEC] set static current limiting
set sequence pos 3
set sequence pos 4
[SEC] setVoltage 1
[SEC] sleep 200ms
child has terminated
pipes closed
pipes closed
[ePopen] command: route -n | grep eth0
poll: unhandled POLLERR/HUP/NVAL for fd 30(16)
poll: unhandled POLLERR/HUP/NVAL for fd 32(17)
[SEC] invalidate current switch params
[SEC] sendDiseqc: e00000(DiSEqC reset)
[SEC] sleep 50ms
pipes closed
0.0.0.0
169.254
192.168
nameservers: [[192, 168, 1, 1], [192, 168, 1, 1]]
read configured interface: {'lo': {'dhcp': False}, 'eth0': {'dhcp': True}}
self.ifaces after loading: {'eth0': {'preup': False, 'predown': False, 'ip': [192, 168, 1, 10], 'up': True, 'mac': '00:1d:ec:07:1c:77', 'dhcp': True, 'bcast': [192, 168, 1, 255], 'netmask': [255, 255, 255, 0], 'gateway': [192, 168, 1, 1]}}
AT plugin not found
ER plugin not found
resolve: resolve ${libdir}/enigma2/python/Plugins/Extensions/WebInterface/plugin.py
resolve: -> /usr/lib/enigma2/python/Plugins/Extensions/WebInterface/plugin.py
resolve: resolve ${libdir}/enigma2/python/Plugins/Extensions/OpenWebif/pluginshook.src
resolve: -> /usr/lib/enigma2/python/Plugins/Extensions/OpenWebif/pluginshook.src
[OpenWebif] no plugins to load
[OpenWebif] started on 80
poll: unhandled POLLERR/HUP/NVAL for fd 31(16)
[SEC] sendDiseqc: e00003(DiSEqC peripherial power on)
[SEC] sleep 150ms
[SEC] sendDiseqc: e01038f4
[SEC] sleep 50ms
set sequence pos 3
set sequence pos 3
[SEC] update current switch params
[SEC] startTuneTimeout 5000
[SEC] setFrontend 1
setting frontend 0
[SEC] sleep 500ms
(0)fe event: status 0, inversion off, m_tuning 1
(0)fe event: status 1f, inversion off, m_tuning 2
OURSTATE: ok
[eDVBCAService] channel 0x1fba4a8 running
[eDVBLocalTimerHandler] channel 0x1fba4a8 running
no version filtering
0014: 70 00 00 00 00 00
mask: fc 00 00 00 00 00
mode: 00 00 00 00 00 00
[eEPGCache] channel 0x1fba4a8 running
[EPGC] next update in 2 sec
stop release channel timer
0012: 4e 21 36 00 00 00
mask: ff ff ff 00 00 00
ok ... now we start!!
0000: 00 00 00 00 00 00
mask: ff 00 00 00 00 00
eventNewProgramInfo 0 0
have 1 video stream(s) (00a1), and 1 audio stream(s) (0054), and the pcr pid is 00a1, and the text pid is 0023
allocate demux
disable teletext subtitles
decoder state: play, vpid=161, apid=84
DMX_SET_PES_FILTER(0xa1) - pcr - ok
DEMUX_START - pcr - ok
DMX_SET_PES_FILTER(0x54) - audio - ok
DEMUX_START - audio - ok
AUDIO_SET_BYPASS(1) - ok
AUDIO_PAUSE - ok
AUDIO_PLAY - ok
Video Device: /dev/dvb/adapter0/video0
demux device: /dev/dvb/adapter0/demux0
VIDEO_SET_STREAMTYPE 0 - ok
DMX_SET_PES_FILTER(0xa1) - video - ok
DEMUX_START - video - ok
VIDEO_FREEZE - ok
VIDEO_PLAY - ok
DMX_SET_PES_FILTER(0x23) - ttx - ok
DEMUX_START - ttx - ok
VIDEO_SLOWMOTION(0) - ok
VIDEO_FAST_FORWARD(0) - ok
VIDEO_CONTINUE - ok
AUDIO_CONTINUE - ok
AUDIO_CHANNEL_SELECT(0) - ok
not pauseable.
[AutoRes] service changed
[eDVBLocalTimerHandler] diff is 0
[eDVBLocalTimerHandler] diff < 120 .. use Transponder Time
[eDVBLocalTimerHandler] not changed
-+ 1/2 TID 4e
+ 1/1 TID 00
done!
PATready
use pmtpid 0501 for service_id 2136
0501: 02 21 36 00 00 00
doing version filtering
0000: 00 00 00 0f 00 00
mask: ff 00 00 3f 00 00
mode: 00 00 00 3e 00 00
VIDEO_GET_EVENT - ok
[AutoRes] got event evVideoSizeChanged
[SEC] set dynamic current limiting
[AutoRes] got event evVideoProgressiveChanged
+ 1/1 TID 02
done!
have 1 video stream(s) (00a1), and 2 audio stream(s) (0054, 0055), and the pcr pid is 00a1, and the text pid is 0023
[eDVBCAService] new service 1:0:1:2136:400:1:C00000:0:0:0:
[eDVBCAService] add demux 0 to slot 0 service 1:0:1:2136:400:1:C00000:0:0:0:
[eDVBCIInterfaces] gotPMT
demux 0 mask 01 prevhash 00000000
0501: 02 21 36 39 00 00
mask: ff ff ff 3f 00 00
++ 2/2 TID 4e
done!
[CCPrioMaker] search /tmp/ecm0.info
0012: 4e 21 36 37 00 00
[AutoRes] determineContent
[EPGC] start caching events(1416154439)
sdt update done!
[EPGC] abort non avail schedule reading
[EPGC] abort non avail schedule other reading
[EPGC] abort non avail viasat reading
[EPGC] abort non avail mhw reading
[EPGC] nownext finished(1416154446)
[EPGC] stop caching events(1416154446)
[EPGC] next update in 60 min
action -> InfobarSubserviceSelectionActions DeliteGpshow
reused converter!
reused converter!
reused converter!
warning, skin is missing element key_yellow in <class 'Blackhole.BhGreen.DeliteGreenPanel'>
warning, skin is missing element key_blue in <class 'Blackhole.BhGreen.DeliteGreenPanel'>
warning, skin is missing element key_green in <class 'Blackhole.BhGreen.DeliteGreenPanel'>
warning, skin is missing element key_red in <class 'Blackhole.BhGreen.DeliteGreenPanel'>
action -> WizardActions right
unknown action WizardActions/right! typo in keymap?
action -> WizardActions down
unknown action WizardActions/down! typo in keymap?
no ancillary data in audio stream... abort radiotext pes parser
action -> WizardActions ok
File "/usr/lib/enigma2/python/Components/ActionMap.py", line 46, in action
res = self.actions[action]()
File "/usr/lib/enigma2/python/Blackhole/BhGreen.py", line 44, in save
File "/usr/lib/enigma2/python/Blackhole/BhGreen.py", line 50, in run
File "/usr/lib/enigma2/python/Plugins/Extensions/CCcamOscamInfo/plugin.py", line 117, in main
(ret, res, oscamconfigpath, cccamconfigpath) = read_Config_Files()
File "/usr/lib/enigma2/python/Plugins/Extensions/CCcamOscamInfo/shared/readConfigFiles.py", line 18, in read_Config_Files
tasks = os.popen("ps -ef")
OSError: [Errno 12] Cannot allocate memory
(PyObject_CallObject(<bound method ActionMap.action of <Components.ActionMap.ActionMap instance at 0x1f7c990>>,('WizardActions', 'ok')) failed)
</enigma2crashlog>
<pythonMD5sum>
</pythonMD5sum>
</crashlogs>
</opendreambox>
Thank you shiro.But we are not technicians.You speak about clean image ... meoboot...big swap...we don't know what this mean. Give us operations step by step or give us image as you have done with all images before 2.1.2 and 2.1.3...all my respect Shiro.
I've installed from scratch, that is before I put the deco on factory mode, and install, and I get problems everywhere.
I do not recognize the swap, green screen by selecting ddns turns, opening StreamTVplayer and also by double-clicking the blue button
anyway I can not follow.
I downgraded to 2.1.2 version and now it's working perfectly again ( in 2.1.2) , so I'll wait for the revision of 2.1.3 before updating.
Thank you shiro .I am a fan of Black Hole so i can't go to another image and hope solution for 2.1.3 on vu soolo .thank you very much for your efforts.My respect.
Ok guys.
Issues of bh 2.1.3 with Vu+ solo box are confirmed.
We are investigating.
THANKS A LOT.
Image is really very good at sight (new skin).
You can also "block" download for 2.1.3 for SOLO since there are too many bugs and close the thread, maybe, until resolution.
Thanks a lot for the good work for our solos.......... :-)
Thank you ...
i have problem with HDMI cable.
Is there someone who can help me please???
my cable HDMI doesn't connct my Vu+ solo with my tv LED samsung.
i change the cable but the same problem.
please help me
thanks everybody
Hello, I have tested this version this morning : PERFECT , by cons I can not run my WiFi key = > After installing it detects r8188eu WLAN Adapter == > no .... AP + crash has repetition time search
Please help me.
For information I have a wireless USB ( RTL8188ETV Realtek Wireless LAN 802.1
Bonjour, j'ai testé cette version ce matin : PARFAIT, par contre je n'arrive pas faire fonctionner ma clé Wifi => Aprés installation il detecte r8188eu Adaptateur WLAN ==> pas d'AP.... + plantage a répétition au moment de recherche
aider moi SVP.
Pour information j'ai une clé Wifi USB (Realtek RTL8188ETV Wireless LAN 802.11n)
