Black Hole Vu+ Solo 2.1.5
Black Hole 2.1.5​
  • New: HQ 5 Full Hd Skin 1920x1080 (duo2, solo2, soloSe, uno, ultimo, zero)
  • New: OpenGL animations and Xbmc (duo2, solo2, soloSe)
  • All drivers updated
  • fix autoresolution plugin
  • [hbbtv] fix crash parsing xml
  • [hbbtv] fix VOD play problem
  • fix keymap bug
  • fix channel skip
  • change default resolution to 1920x1080 (only models with full hd skin)
  • update languages hr, it, no
  • meoboot: add support for OpenGL and Xbmc images
  • update Usbtuner
  • WIFI: update driver RTL8188EU
  • WIFI: update driver RTL8812AU
Warning: This image MUST BE INSTALLED IN FLASH.
Warning: Don't mix images with OpenGL animations and images without animations in multiboot because they use different drivers. If you have an OpenGL image in flash you can only use OpenGL images in Meoboot.
Warning: Previous personal backups are not compatible with this image. Please use software manager to backup your settings before you flash.
Known Issues: Xbmc External Player not working yet.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Hello and thank you so much for your great work.
I have installed this image and all is OK with fantastic performance. The only problem is that I get all menus in a small size.
Please, could you help me with this issue?
Thanks in advance.
Best Regards,
Hello friends, I bought a Vu + SOLO, and I'm trying to flashing the "Black Hole 2.1.5", like this:
1. I insert the pen (already tested it with several different)
2. I turn on the electric current
3. is only in red light :(
try clicking the "Standby" and nothing happens does not give any information on TV or appear green light :(
Anyone know what can it be? I think this box is clone, comes with a sticker indicating a site:
Your box is 1005 a clone. No support for it. Clones not welcome here.
Ask refund if the "seller" has sell the box as original and buy a better genuine box (Vu+Zero for example).
Just buy a original box my old friend... ;)
bugs, bugs,
Very often it restarts,
Other times the Blue circle flickering light, and plant on the current channel, and will not accept any commands from the remote control, and I must disconnect the electricity to restart.
