Black Hole Vu+ Solo v. 1.5 Multituner
Hi,
I installed the 1.5 version to my Vu+ Solo and switch it to Czech language. There are some incorect and missing special czech characters -letters now. I din not have this problem on my previous 1.4.4 version. Is there any way to correct the encoding ? Thank you
Are you using the default skin?
Yes, I did not make any change. I could see a first problem already in wizard language selection screen, where characters are not shown correctly.
Problem with incorrect charracters is fixed after changing a different skin. Thank you very much for your tip.
I have one more question: Where I can find correct c c c a m for Black hole image ? Thank you
I'm happy to read you have solved the problem about chars but talk about Emu/Cams is not allowed here. Read rules please!
Let me to ask you again back to my problem with incorect characters. I tested several skins, but I still prefer most the default BlackHole skin. Is there a chance to modify it by using a functional althernative skin in order to make it display characters correctly ? I assume it must be a font or codding problem which should be somehow possible to change right ? Thank you
