Black Hole Vu+ Solo v.2.0.0 OE 2
Very good job! Just one problem so far...
Timezone is not working for me either. Flashed it twice... still the same problem.
I've installed OE2.0, run an update and then set up extended flash in the Avalon parallel universe. But the box wont boot into Avalon and if I try Menu--> Teleportation or Extra Settings --> Devices Manager I always get a GSOD.
Many thanks, we are aware of this issue.
Hi guys, hi Crew.
Thanks a lot for BH 2.0.0. I tested it yesterday all day.
I turn back to 1.7.9 this morning, since 2.0.0 is not stable on my Vu+ SOLO in default configuration (no addons, no skins but default, ita language set).
1) IMPORTANT: too many green screens (system info [also after online update], device manager, 1 time during online update procedure) [last 2 attached]
2) NOT SO IMPORTANT: ipkg isn't onboard anymore
3) NOT SO IMPORTANT: webif has a different behaviour since 1.7.9 in same version 0.1.3 (large screen panel in bouquets, 2 icons for streaming, 1 with standard port 8001 1 with port 8002 also with 1 tuner, url in 1st icon target is # (managed with javascript) not full url [http://decoder:8001/web/stream............])
4) finally DVD PLAYER is fully working, GREAT!!!!!!!!!!!! :)
This is just a report by a BH user to make it always better, please do not consider a disapproval...
THANKS A LOT!!!! Great developers!!!!!
[Problem Solved ] Format your USB with FAT and not NTSF
Greetings.
Hey Everyone,
There's a problem while installing BH 2.0.0 where the receiver doesn't boot from the USB pen , is there something should i install it or do it before installing the image ?
Thank
Thank for your works , But in my Solo positioner not working with USAL . help me to set my motor dish with this image .
thanks
I've always had this GSOD problem on my Vu+ Solo when I access Device Manager to change the mountpoint of my USB stick. I'm surprised that the problem still exists after all this time.
When I download and install new addons from the Addons Download Manager nothing happens!
Addons are actually not being installed... atleast there are nowhere to be found... had the same issue with 2.0 skins and picons.
Note that I updated my box through Online Black Hole image update.
Many thanks to the team
but still green screan with device manager Or when i use streamTVplayer, after update rev B
