Black Hole Vu+ Solo v.2.0.1 OE 2
Correct, was a bug in EclipseHD_B_HC in MyTube player,
but why you did not report it .
I would ask you to do that next time.
Now I have fix this bug and you can use with MyTube player.
Thank you Matrix,
I didn't report because I thought that is not so significant problem while we have enough other skins which can use instead EclipseHD_B_HC. Next time if I found some mistakes I will report it.
Regards
in ver 1.9.x backup files are .bh3 but in ver2.0.x are .bh4
I ll restore only channel list and buq
in first day after restore we have not problem
but 2 day or 1 day later this is my problem and I write it here
Ill rename it to .bh4 and it worked
sorry bot I think this bog is not linked to backup version or anything abut restore a channel list from other version
Ill be test it but if don't work or anything abut it I ill be write here \
thanks for no good help
I thing managers responds are not
enough
Hi,
I try to install skin EclipseHD_S_BH in BH 2.0.1, vu+ solo, but it doesn't work, hava always default skin.
And Airplay doesn't work
Any information ?
enough
I repeat, you can't use 1.7.x backup for 2.0.1 (it's valid also for skins), for channel backup/restore you can use Vu+ Control Center or Dreambox Edit on PC.
No good help? You still do not follow recommendations.
A little thing only. When pressing yellow button, i get pause as in earlier images. As I also use Duo i can see that its ok in Duo, Audio menu shows up. By the way,
i use Neutrino Keymap with "neutrino" setting i both Solo and Duo. Any suggestions?
Anyone?
I don't know, what skin you are using and how to change option to "Use keymap Neutrino - no" or "Use keymap - enigma".
I'm using BH 2.0.1 with default skin and everything works fine for me.
