Black Hole Vu+ Solo v. 2.0.4
On some channels ,there are wrong chars in subtitles,particularly channels shared between the Scandinavian market, where same channel is localized to Danish / Norwegian /Swedish.
Channels like National Geographic and Discovery etc.
In Denmark we have theese 3 special chars æøå(Capital: ÆØÅ), they are somehow replaced with the swedish counterpart.
A list of changes are as follows (ascii value in parenthesis)
The chars that changes are:
å=å (OK)
æ (230) becomes ä (228)
Æ (198) becomes Ä (196)
ø (248) becomes ö (246)
Ø (330) becomes Ö (326)
TTX Page 693 Danish
Subtitle language selection =Danish,also tried setting to none, no difference in this matter.
When i click subtitle button, the page activated is TTX Page 693 Danish
I tried change to other nordic languages such as Norwegian or Swedish, they work. It looks like their äöå/æøå are correct.
I have not seen this behaviour until 2.0.4 ,not a big deal, just noticed it and thoutght i would mention.
very good i want to upgrate to 2.0.4 because i like erery thing new
but i ask if i can pass to 2.0.4 by blackhoe server directly
thanks
i installed but after setup with usb flash
on all dvb-s2 channel is off ? and no signal
older version my box is 2.0.3
Hey guys.
I set up EPG sync with internal epg management at 04:00 at morning.
It's ok, but after sync is done, STB doesn't go standby but stays on epg channel.
Is there a way to make it standby after sync, without other cron scripts?
Hi Guys,
I've just installed 2.0.4 but I'm having trouble connecting with Filezilla. I get the following error: Connection attempt failed with "ECONNREFUSED - Connection refused by server". Has the usernam / password changed for 2.0.4 by any chance?
I have another box which is running BH 2.0.3 and I can connect to that just fine.
Anyone got any ideas?
Hi Guys,
Seems that the FTP service is not started.
Please take a look into Blue Panel -> FTP Service if it's started or not
i have installed this image, but when i want to watch bbc hd channel, the receiver crashesh and restarts, it happen every time i want to watch it, any suggestion?
You use a ready-made list?
I guess you have bad sat list (settings) list.
Try to make manual scan of the satellite to correct errors in the list
or use different list.
thanks for replying, i have tried as u said, but the problem exist again, in the same frequency on the bbc knowledge hd channel there is no problem, but bbc hd as soon as i change to channel to watch it, i see a green panel of crash/ error report and solo restarts
