Black Hole Vu+ Solo v.2.0.8
Hi,
Bug observed in this and previous images:
-Can not correctly select the audio tracks: Astra 19 º 10847V 22000 5/6 (With the DM500 works perfect)
-TDT does not work APPROX APPTDTUSB (TDA18211HD AF9015A)
-Incorrectly indicates the selected antenna Diseqc (A, B, C, D)
regards
The DM500 is Enigma1 box and should be different approach on DVB services than Enigma2 software.
Are you using Auto Language Feature to avoid this problem?
Open a thread in the corresponding section of this Board about DVB-T USB devices.
Explain better please.
Did someone/something bite you?
With this attitude you can't go anywhere pls first more respect each other's you can't just say my boxes crashed and expect no respond if you don't want any help why posting your box is crashed if there some thing wrong whit image team will try to help you and another's
Listen to me... i ONLY want you all Team to know that STRANGELY my stb crashed just after wizard ended... as never before... is this a CRIME ?????????????????????????????????????????? :-| :-| :-| :-| :-| :-| :-| :-| :-| :-|
Anyway, OK, i WILL only download your wonderful firmwares without saying anything, if this is the forum policy !!!!!!
Byebye.
Byebye.
You violated our board rules and you are banned for a month!
Goodbye
instable image .my stb crash many time.it show no signal .sometimes no image only audio .
telecomande no reaction​
This image has been installed on thousand of Solo and you are the only one to write these things.
Therefore I suggest you to download and to install again the image without restore backup.
I have 3 antennas (Astra, Hotbird, Hispasat) with a diseqc switch, changing channel always shows "A" regardless of whether this in Astra, Hotbird and Hispasat.
On the audio language selection was set by default to None, I tried to change it to the original and any undetermined unsuccessfully.
Sorry for my English,
thanks
thanks
The letters A, B, etc. regard the tuner used, not the satellite.
thx iwill try again .perhaps the usb didnt formatted correctly
