Black Hole Vu+ Solo2 1.7.9-3
We've tested text scrolling on the VFD display.
Do you realize that it dramatically slows ZAP
and therefore in principle is bad to be used for those
who prefer a quick zap.
I personally I'll never use something like that .
I think it should be clear that these movable elements in skin or in VFD use much processor
and slow down the rest.
And of course it is a matter of choice.
But for me personally, an option that has no practical value
and has a negative effect on the important stuff.
I don't know which skin will allow it on 1.7.9-3.
VTI 5.0.1 on Solo2, OpenPLi 3.0 on Duo, you have to set it in HD Glass menu (type of OLED visualisation: Vu+...)
But this is a Vu+ Solo2 BH 1.7.9-3 section. So, these are not a questions for this place.
You already answered it three posts above when somebody asked about scrolling IN solo2 179-3 thread:
Yes, some skins allows it
just wanted to clarify: which skin?
As far as I know there is no skin which allows scrolling ATM without some image modification.
That's it.
That's it.
I'm sorry, I forgot, that this is
section and not Vu+ Duo.
My working HDGlass16 version on VTI 5.0.1 is 7.18 (with some bugs, but usable)
is there a way to have PIP enabled while a recorded channel plays in the main window.
I mean live channel on PIP window and recorded channel (via EMC) on main and swap between them?
Helo my solo2 not updated by usb stik,this just UBIFS UPDATE on the skren now about 10 min.... HELP PLES IMAGES I FLASCHING 1.7.9.3
