Black Hole Vu+ Solo2 2.0.2 Rev. A
Hi,
WiFi the TEW-624 (Ralink) adapter works normally, but the LED isn't shone. Why? In version 2.0.1 everything was normal... Thanks.
just updated with new BH Image using Formated usb stick after reboot message on TV resolution not supported change resolution of external device
well gutted please help
You picked the wrong video resolution that is not supported by your TV ???
Maybe you have setup 1080p that is not supported by your Tv like Matrix told.
Reflash again an be careful to select a supported resolution at config step.
If you have a null-modem cable you can try to see what bootloader reports.
Contact your seller to try to change your broken box.
yesterday i try to connect box by null-modem cable through putty
But only appear incomprehensible message :
and i can not write commands
But I noticed before this problem occurs a message appears on the front
Meaning that the device blocking
Please don't post hundred of messages into the Board.
You have opened a dedicated thread about your problem: every discussion should be processed into your dedicated thread.
Again: contact your seller and ask it to change your broken box.
Black Hole 2.0.2 Rev. A
What is new ?
  • NEW: Add Dvb-T frequency and bandwidth infos in Osd
  • DISABLE manual DNS settings (back to automatic config)
  • Update On Demand plugin to latest version
  • Update Russian and Croatian translations
  • Add AutoShutdown plugin for all models
  • Fix e2 crash when rollof option is set to auto
THIS IMAGE CAN BE ONLINE UPDATED FROM VERSION 2.0.2
For those who have problems with the network after image update.
1) Switch to DHCP first in network Configuration to reset network
2) reboot.
After that, you can config your network if you like to change.
DNS name server is automatically configured.
The image MUST be installed in flash.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
hi, can anyone tell why when i install this image via usb it sticks on UBIFS Update?
