Black Hole Vu+ Solo2 2.0.3 Hyperspace
No, do an settings backup before flashing. Your settings will be recovered after without problem. You have to reinstall only plugins and addons.
Many thanks for prompt reply - much appreciated just like BH
Sent from my iPad using Tapatalk HD
Warning: due to Kernel update and structural changes the Personal Backup of previous Black Hole images are not compatible with the 2.0.3 version.​
I'm afraid to download this update to the large number of conditions. In addition to that Solow 2 has enough space.
Solo2 has plenty of space but the main update with solo2 is the improvement in picture quality which comes with the kernel update.
Really you must update to benefit.
So does this mean re-entering all motor positions as logged before and it should work?
Or do I need a man with a meter to drive it to positions and store them that way?
USALS never worked for me - a long story. Not least as there's a Church Tower involved hence moniker.
Sorry to be a newbie bore!
I update a box for a friend, I just took a picture of his config, added it to the new image and it was easy.
Remember no one makes you update but you could be missing out :)
