Is there any way I can edit the Extensions panel (blue button long press)? I want to remove some of the options in that menu, but how can I do that?
NO
I do however have a different opinion
especially after intensive testing.
This error we had without CrossEPG in the images (not only bh image)
The error in the log does not mean conflict between each epg
but bad EPG data in the EPG.
Enigma Protective react and release / crash.
So there is no need to remove CrossEPG
On the contrary.
CrossEPG works very well, this is more question of good data on EPG server or sat.
EPG quality on them.
Do not forget we have a new option in the panel for the EIT
with which you can select the appropriate EPG
with priority for NET or Satellite EPG.
So experiment until you find the best solution for yourself.
Sometimes EPG crash
is inevitable.
A small error in the EPG data will crash
E2 system.
Miro, apologies for maybe cross-posting it, but this issue gets really annoying for us watching HRT channels, might be the same for others with special character entries, don't know.
So, yes, I have clean install 2.0.2 and did not even install anything else, or turn on, just pressed EPG button on HRT2 and it crashed. Is there maybe a way to intercept the situation, can somebody look at it?
I did research on this and on old CrossEPG support site there was issue mentioning ISO-8859-2 unsupported encoding, precisely for HRT channels, maybe somebody can look at it and see if there is a way to intercept and prevent crash.
Here: http://code.google.com/p/crossepg/issues/detail?id=30
And attached is (one of) my crashlog(s):
OK, thanks, but please note this is nothing actual or recent in my case. It happens "since ever" and only on HRT channels. Why was this last crash interesting, well, because I JUST installed image, not sure if EPG was from net or service, it might as well be the one from service. Is there a way for me to test it without any EPG, except for one that comes from service? Because if it crashes then, it would be easier to find the real cause. In a way I was hoping coders can add extra protection layer preventing this to happen, but then again finding the exact cause rather than "fixing it with a hammer" might be better option.
Another thing that could be helpful, exactly the same crash often happens even when you just open the bouquet with HRT channels, it shows list of channels but at that point it freezes, spinner comes up and it crashes in few seconds. The very same way it can crash when you just press down or up key, it displays the list of channels but spinner comes up and it crashes in few seconds.
I repeat, in my case, this happens exclusively with HRT channels and with bouquets that have them in, I watch 4 sats, have thousands of services with EPG loaded and it never ever happened on any other channel/bouquet than HRT. So I'd suspect it could have something to do with special characters, but can not be sure of course...
What, you work now!? I thought working for Vu+ is enough to make for living!![]()
I use the latest BH 2.0.2 on solo2 and luckily took a backup as soon as I set it up running.
About an hour ago, I updated to Rev A and rebooted as usual.
But as soon as I switched to a DTT channel using A867, after 5 seconds I got the green screen.
Tried again same result. Rebooted again, tried once more but same result.
Now I've re-installed the backup (without Rev A) and I can view DTT channels as before.
Any suggestions please?
No problems with EPG on HRT HERE
No problem with the EPG from transponder
No problem with the HRT EPG from CrossEPG
No crash and freezing
Letters displayed without problems
EPG for 6/7 days CrossEPG
Miro, I kind of feel we are OT here, but I found related post with this thread and simply replied.
However, what I'm trying to confirm or deny is that in my specific case with new image just loaded there was no EPG from Net. At all. If I'm not mistaken I did not even switch on the network at that point, meaning bad EPG might have come from service. Is this possible? Is there a way to test this? How do I completely switch off network EPG and use service one only? And in case this can come from the service itself, would that maybe deserve somebody to look at it and see if any kind of protection can be built in? If I got it right, this is now BH Enigma, with complete code in your hands, so maybe coder(s) can check it?
Many thanks for your time and all of you guys doing great job!
Well im using bh 2.0.2 updated to rev a now just randomly it just locks up with the little bh timer in top left moving a little every 5 or so secs. But just never comes back to life. Does any one else have this problem. It happens even if im just watching a channel and im not running and apps doing something like cooltv guide or watching a recorded program. Infact I could just leave the room come back and just find it like it. Have to turn off and reboot several times a day. Only seems to of started since upgrade to rev a. I dont get any crash logs of course this is not helpful. Does not responf to ping ftp telnet but the tv channel stays on.
