Black Hole Vu+ Solo2 v.2.0.7.1
Hi!
Many thanks for this new update.
I had a problem with this update in solo2. Transconding doesn´t works with BH 2.0.7.1. I had returned to 2.0.7 and it works again.
Anybody has the same problem?
Best regards!
Hi!
Best regards!
Hello
same here
it seems that the receiver doesn't recognize the difference between the 8001 and 8002 port so the result is the transcoded channels coming out only with max bitrate making the transcoding impossible for 8002 port.
waiting for fix
Hello
same here
waiting for fix
Have you enabled Transcoding plugin?
I'm also having lot of problems since 2.0.7.1 upgrade.
Online update from 2.0.7 breaked completely transcode. A clean install solved the problem.
Now I'm able to transcode TV chanels but not records.
The file stream are "uncompressed" at the original bitrate, no transcode at all, so unusable on 3G connections, both on VU+Player and DreamDroid.
Also, there's no more an option to enable or disable transcode in plugin enclosed in 2.0.7.1.
PS: no way for file transcode using VU+Player and DreamDroid, but works fine on PC using VLC via OpenWebIf on port 8002 just like for live tv...
I have not tested with solo2 but with DUO2 transcoding works
You have to choose the port that you want for the mobility device that can be either of these two ports.
When you pick the port, he is active and enabled.
On duo2 it gets confirmed in the window.
one is enabled for PC and the other for Mobil device.
Does anyone know how to set up Blackbox for IOS using transcoding option. I cannot get it to work with transcoding option. No problem with that option disabled. But i want to use it outside home network and therefore I need to use transcoding on port 8002. Any ideas? I have tried it on BH 2.06 also without success.
[quoteerstmal trix10, post: 116119, member: 9"]1.NO Problem
2.NO Problem Media Portal from BH server version 4.9.2 working .[/quote]
Danke erstmal für deine antwort das es geht wusste ich auch da es beim ultimo diese Probleme nicht hatte
Auch nach dem update auf 2.0.7.2 war es genauso wieder habe alles wieder neu aufgespielt und es bleibt genauso, habe dann mediaportal bzw.crossepg geloescht und dann von der ulti rueber geschoben und jetzt geht es wie es sein soll
Gruß bodo
Translated google (MX)
Thank you first for your answer it is because I knew it did not have these problems at year-end
Even after updating to 2.0.7.2 it was just re did everything again filled with new and it remains the same, I then deleted mediaportal bzw.crossepg and then pushed from the ulti rueber and now it is as it should be
Greeting bodo
Ok, problem is only with VU+Player app, it calls my Vu box on port 8001 instead of 8002 for records.
Hope will be updated soon.
No problems with DreamDroid configured to use port 8002 both for live and records.
good evening
after updated to bh 2.0.7.2 , ip tv streaming RTSP / RTMP? does not work anymore even with no chain with puling tsmedia, I have all the lib install.
