Black Hole Vu+ Solo2 v. 2.0.7
Hi! Updated image 2.0.7 UNO and Solo2 .... noticed a difference in behavior. At exactly the same installed plugins and settings Uno is more stable . In Solo watch sometimes hang on .... especially if you leave the tuner off mode at night .... treated only with overdrive button. Also recently, following customer complaints, noticed that all can work stably and at a frequency of one particular display too low a signal level and channels it will not show or scans ..... after the overdrive button , everything comes back to normal ... . specifically the customers watched it on 13E 11662 V 27500 3/4 S2 8PSK ( channels Hustler HD-3D, Redlihgt 3D-HD) while all write off to dampy soft ..... although at one time, the UNO- DUO SOLO - Ultimo such diseases was not ....
So you might agree with me that the remote control sensitivity has changed and it is a 2.0.7 problem! I have found that when I watch an hd channel, only in that case the receiver hangs and I don't think it's normal for a dual core cpu! Which is the override button you mentioned above?
Thanks for effort, but regret to say 2.0.7 is quite unstable on Solo2 is part of Media playing movies over the network - bugs related to IR remote handling (it doesn't recognize any key/code until reboot).
is there a way of getting back the following functions that were in past Images?
1. after Movie Play - Option to delete movie
2. Edit mode for Channel list (move channel)
many thanks...!
Black Hole 2.0.7​
  • Update skin to Matrix10 MX S2
  • New drivers 20131023
  • - Support DVB T2 Tuner(uno, ultimo, duo2)
  • - Support file transcoding(solo2, duo2 : needs an image update)
  • - Fix delivery system bug in vtuner
  • - Fix DDP passthrough(solo2, duo2)
  • [transcoding setup] support filestreamproxy(8003).
  • Update OpenWebInterface
  • [mt7610u] new driver v3.0.0.1
  • [mt7610u] added new driver v3.0.0.2
  • [blindscan] fixed bug in ScanNimsocket function.
WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot. The image MUST be installed in flash. Black Hole does not support images not installed in flash.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits Thanks to Pedro_Newbie for Backup script
DISCLAIMER
LICENSE (TERM OF USE)
Many thanks
opkg update fails also opkg install enigma2-plugin-extensions-ondemand after installing black hole 2.0.7 on vu solo 2.
Black Hole 2.0.7​
Addons
Infobar / OSD
Analog Clock Gui
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
UPnP Client Djmount
Pcsc Panel
Tuner Server
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
BlackHole
Avalon
Chaos
Ghost
DISCLAIMER
Thank you for the great work
