Black Hole Vu+ SoloSE 2.1.3
lorenzo64
Black Hole 2.1.3 Universal Meoboot
  • MeoBoot updated and now compatible with all major images
  • New Army skin DarkSky
  • New fade effect in osd
  • OpenWebIf updated and added Italian translation
  • Httpstream updated:
    - added chunked transfer support.
    - connect to TS stream in seperate thread.
    - add basic http authentication support.
    - add redirect and playlist support.
  • Elistbox: add setFont function (workaround for Full Hd skins)
  • media-tree rebuilded module list
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-2.1.3-vusolose_usb.zip
belfastdaren
still got same crashing green screen on utv hd on cable i have added crashlog
  • enigma2_crash_1415900393.rar
Cleric
Thank you as always for all your hard work which is greatly appreciated
Just proves why BH is the strongest and best image
Scaro
hello Angel,
I tried this image to and still have the crash as 2.1.2. on chanel HD C*n*l + . swiss cablecom
I have no problem when puting old scan channels but after new scan, crash come.
Scaro
here it is the crash report
  • enigma2_crash_1416813379.log.zip
Scaro
Ok ,
with cable tuner in switzerland don't use the cablecom schweiz setup !
use the setup as show in the file and it will works fine
  • Capture d’écran 2014-11-24 à 09.46.51.zip
