Black Hole Vu+ Ultimo 1.7.7 HbbTv
lorenzo64
Black Hole 1.7.7 HbbTv
  • What is HBBTV?
    HBBTV is a pan-European specification for interactive TV applications with its roll-out in Germany, France and more countries are now following. HBBTV has been developed in order to fulfil the needs of seeking ways to deliver interactive services through a single web-based user interface. The fundamental goal is to create open standards providing the seamless TV experience to customers.
  • Note for Vu+ Ultimo and Vu+ Uno boxes:
    Remeber to upgrade the firmware to the version 4.5 before you install Black Hole 1.7.7
  • Note HbbTv:
    To access HbbTv functions: Short press red button / Long press blue button
  • Warning Parallel Universes:
    Bh parallel universe panel has been moved to: Long press red button
  • What is new ?
  • Vu+ dvb drivers updated to 20120824
  • Vu+ OE updated to 20120830
  • Vu+ Enigma2 updated to 20120830
  • Army skin Transparency-HD updated for HbbTv
  • [librtmp] fix build bug
  • Enigma2-defaultservices : update default services
  • Opera hbbtv:
    - upgrade libdvbsi++ package.
    - include hbbtv plugin.
    - packaging opera-hbbtv binutil.
  • Fix libpcsclite build
  • RemoteControlCode : support for all models except duo/solo.
  • [firmware upgrade] fix fimrware data filename.
  • Add opera browser.(with hbbtv)
    - handle error for forbidden stream.
    - activate red button.(ready for ait..)
  • keymap.xml: Red button remapped: short = hbbtv, long = parallel universes
  • BhEi: fix satellite name and position in osd (thx Sato)
  • Add filesystem choice to usb format wizard
  • Remove Vu+ Device Manager, using Bh device panel instead.
  • Set platform profile and check HbbTv application version.
  • HbbTv: fix bug of setting orgid.
  • Fix lamedb.192.
  • [hbbtv] fix bugs.
    - add platform profile.
    - add application version.
    - notify error for failed to load.
QUI
picciuotto
Solo Una domanda . X installare questa immagine si deve prima installare il pluig - vuultimo_fpga_ver_4.5 - ?
Adesso ho sul mio VUultimo la BH 1.7.6
Diamondear
Probabilmente mefisto intendeva OE2.0 che ha il nuovo interprete (Linker). Sicuramente tutti i plugin compilati (.pyo) con il magic number vecchio non andranno.
Diamondear & HTC Sensation XE con Tapatalk 2
Diamondear
Esatto intendevo quello.
Oggi l'ho installato la versione 1.7.7 sul mio VU+Uno e il firmware utilizza lo stesso linker, per cui tutti i plugin vanno ancora bene. Il problema si pone solamente se installi una immagine OE2.0 con meoboot, che ti da l'errore "bad magic number". Bisogna chiedere al TEAM se hanno intenzione di compilarlo anche per versioni OE2.0.
gobi2000
Da quato ho meso la versione 1.7.7 usando un hdd 500gb interno 2 tuner dvb-S/2 1 tuner DVB-T/C 1 tuner USB DVB-C 1 hub usb 7x1 e 2 pcsc 3121 dopo circa 30 minuti si bloca tutto e non riparte solo con restart, la 1.7.6 va seza problemi con lo steso config, sul 1.7.7 non ho ne anche crash.log.
angelofsky1980
BlackHole Driver Specialist
domanda...giusto per capire qualcosa di piu.... cos è il fpga?
Ogni volta che si aggiorna con una nuova immagine non viene prima cancellato tutto?
perche allora l fpga bisogna istallarlo prima,dopo non si cancella?
L'FPGA è un chip sulla mainboard di Uno e Ultimo che può controllare svariati componenti.
Nei box citati, l'FPGA è colui che controlla e pilota i tuner oltre ai driver :) ed avendo una memoria interna tutta sua, non è intaccato dalle operazioni di flash delle varie immagini.
Cyborgmoon
ok...ho capito.......ma credo che da me sia capitato qualcosa.
io avevo la 176......ho messo il fpga come detto sopra (i 2 file nella usb e ho usato il pluging firmaware upwade)
poi ho istallato la 177........
il problema è questo ,avendo un dualfeed (13 e 19) in fase di configurazione semplice (disiquest ab)
mi fa settare come primo satellite hotbierd......ma nel secondo o metto hortbierd o non collegato.......
in poche parole non posso piu settare astra.......che posso fare?
Diamondear
Sembra strana questa cosa, probabilmente i tuoi settings sono per il mono feed e non dual. Installati una lista per dualfeed e poi riavvia il decoder, dopodiché configura i due tuner.
Avrai il file satellites.xml con solo un satellite.
Ciao
Cyborgmoon
Ciao
Ho gia istallato vannibal dualfedd e riavviato piu volte
........la cosa strana e che inizialmente al wizard mi ha fatto settare i tuner e li era tutto ok.......poi dopo aver istallato la lista mi dava tuner non settato......
sono andato nel menu....alla configurazione tuner e li non posso settare nessun altro satellite in piu di hotbierd!
posso riinstallare l fpga?
Cyborgmoon
ho istallato via internet l ultimo fpga....... è normale che invece di arrivare a 100/100......è arrivato a 84/100 e mi ha detto istallato?
comunque dopo ciò si è riavviato.......ma la configurazione rimane quella......o 13 o non configurato!
help help help.......... prima funzionava tutto!:cry:
Cyborgmoon
....eccomi ancora qua .......
ho notato che la mia lista canali vannibhal scaricata online non contiene i canali a 19.......
l ho rinstallata ma niente.......allora ho visto che il file per la lista a 13 e di 42.63kb........e quella di 13e 19 e di 42.63kb.........è possibile che non me lo fa configurare perche la lista che scarico è in realta quella per un satellite solo?
per inviare i canali manualmente che programma posso usare?
angelofsky1980
DreamBoxEdit o DreamSet ;)
