angelofsky1980
BlackHole Driver Specialist
My net is very good i checked it
Now, i use cable ethernet it work fine but with usb stick no.
If you usually use Wireless network, open a thread in the corresponding section of this Board
In my modest opinion, this last rev I have personal a lot of crash log, one for ejempl.. I'm watching a channel a change to another bouquet and then the box is thinking for a while and then green, after that a loose all the epg channels, I go to back up epg and nothing is save, so I have to download again.
( can you explain how to do it)It's my opinion you are wrong.
You are using a skin not yet supported into this Board (HDGlass).( i been using this skin in the last 7 or 8 versions of B.H and always was working fine, I like also some matrix skins but at the moment I was happy with this,)
About your problem, I suppose you use CrossEPG instead of internal BH EPG system.I use Cross Epg who is integrated in this image and regulary is working fine, I not understand If that will resolve my problem "my epg backup is not working after a crasslog"
First of all try with a BH skin and next try the integrated BH EPG system. ( will resolve my back up problem?? because the Cross epg is working fine, the BH Epg system I dind't use yet because i wass happy with the other one. I will try one day , then to see.
Last option is to enable a swap file of 128Mb.
WellIf you usually use Wireless network, open a thread in the corresponding section of this Board
Try DHCP this help you setup network and next you setup your cfg to this whot was in past.Bloody nightmare. Since I updated I haven't been able to get the wireless connection working. The Nameserver is never recognized. I've left the VU+ dongle out when reflashing the image, and I've not used both the dongle and USB stick at the same time.
I've reflashed like 6 times.
Oh I wish I never updated. 4.8E becomes 4.9E and after a reboot 4.8Ö or 5E. Will never get my boquets in order again. Reminds me of the oe2 times on Dreambox all over again. Like taking a step back two years in time. Sigh.
It is all due to the changed satellites.xml file
if you have your channelsetup elsewhere
then transfer your channelsetup to your box again (dreambox edit).
if not then copy your old satellites.xml file to /etc/tuxbox and reboot and setup your tuners again.
Or generate your own personal satellites.xml file and copy it to /etc/tuxbox and reboot and setup your tuners again.
http://www.vuplus-community.net/board/threads/new-source-to-build-your-satellites-xml-files.6510/
( Active only (and normally Ku-band only) )
Fyi:
After transferring your new satellites.xml to /etc/tuxbox
Reboot your box
Check your Tuner configuration, making sure it is still as expected (My Tuner configuration was changed wrongly)
Fyi:
The satellites.xml file is changed again in BH2.0.2 Rev. C
Best regards
How to get .mkv subtitles to work again? In BH 1.7.x double press yellow and there was subtitles, now they are all gone?
Use AUDIO button on your remote and then select "Subtitles" to enable them.
