Black Hole Vu+ Ultimo 2.1.0
Is it only me, that have problem whit wifi on the lates BH? I cant get wifi to work at all.
Cant finde the wifi setup in this releas, and 2xblue the wifi are deactivate, but cant activate it. Nothing happen.
On the 2.0.8 All was okey..
So, what are im missing here?
Open a thread in the Wifi Drivers section of this Board attaching some details about your wifi dongle used and your wifi network.
Ok there is a workaround to get teletext working for those that need it.
telnet into your box and then type the command
opkg update
and press enter.
Then type the command
opkg --force-overwrite upgrade
and press enter again.
When it has finished, reboot your box and teletext will be working.
opkg update
and press enter.
I followed the steps, downloaded/updated some files, but once teletext appears, I can not get out except restarting the deco.
Regards.
Good working, but small bug detected. I use 2 CAMs for Telekarta and Raduga, both Irdeto. When I switch channel on screen twice blinking CAMs menu. It is only when switching.
Have you setted up the Common Interface Assignment?
Two CAM who manage the same CA must have a dedicated channel assignment. In this manner one CAM decrypts only their channels and vice versa.
