Yes, Black Hole Weather is present.HI PLEASE SIR I HAVE ONE QUESTION WHERE I DONT GET ANY ANSWER SINCE YESTURDAY
SO WANT TO KNOW IF THIS VERSION WE HAVE BLAKHOLE WEATHER THNX
There is a scroll bar in main menuthnx for you answer because when i look to the screen shot is no avaible any way
I fear you can't reduce it.ok then i will install this version because you still here i have one more question do you know how to reduce the screen ouput from openwebif i coneecte to my box via adsl i would to reduce resolution to get good play if you dont know again i say
Probably the issue is due to your network settings.Hi I have installed the new BH oe 2.0 but cannot get the addon server to connect just says connection failed, then I went back to V1.7.9 and doing the same thing? is the server down as no one seems to have reported this.
Thanks for you reply have rechecked the settings and they are ok the only addon that connects are the feed plugins everything else says connection failed.I even tried a non BH image and with the same setting it went straight into there download server,to me it pionts out to a problem with the BH server.Probably the issue is due to your network settings.
Check it.
Just to report that Timezone fix online is never installed!
I try several times update online, i see 2 update package (vuplus-task-base and timezones-alternative), and after reboot i have same updares...
You have to read our board rules (point 4) before to post again!Hi I finally succeeded in installing v. 2.0.0. Due to green screen problems I ended up with deleting my old configuration.
Everything seems to be working fine now except the coded channels remain dark.
I have a valid card from Canal Digital which up to yesterday was working fine. (it is still working in another STB by the way)
Anyone here have an idea what may be wrong?
Sent from my U20i using Tapatalk 2
