Black Hole Vu+ Uno 1.6.7 kernel 3.1.1 beta
thanks for the freat Job , but I see the ROOT size became 98 Mb ( it was 114 Mb ) as I remember .so because of ?
also after installing excort HD V1.1 the box didn't show any thing or respond to the RC , so the old skins are not compatible with this new BH image ?
Hi guys,
I have a problem with tuner configuration,
I've flashed the image but is not a channel,
have tried everything and the configuration is the same as with 1.6.6 bra,
ask for your help.
is my kinfiguration
Port A Astra 19.2 °
Port B Eutelsat 16 °
Have you 2 dishes or a dual LNB? Can you test with single LNB?
Can be a driver issue at this time :(
  • Like
Reactions: tae
I have two single LNB Alps,
I flashed to the front of the image, everything went well,
1.6.6 had no problem with the hmm
plz any one help me in time
the time in my box is diferent in real time about 15 minuet so what can i do
more or less
i cant make it real
1. I would like to clarify. At Solo had a problem with compatibility usb stick (only flashing). Solo only saw Kingston Usb stick. As is the case with this in new image for Uno or image is not the case?
2. Are when it fixed a problem with the display of the Cyrillic alphabet on the front panel?
