Black Hole Vu+ Uno 1.7.0 Multiboot Full Backup
Thanks for your work guys !
But what is the necessity of meoboot ? Is not Black Hole the best image ? :whistling:
for example i use this image bh 1.7.0 because it's the better.but the wobbroser don't work ,therefore i use YTI 4.0 in meoboot when i want using this pluging it's work fine in vti 4.0:yes:
Hi guys, thank you a lot for that new Image... I'm downloading it right now.
I hope that the memory problems are finally resolved by VU+ Team. I'll let you know how it works :-)
THANK YOU !
Hello,
Can we expect a "Classic Light" version 1.7 with no meoboot and no webbrowser or is it the very same as BH 1.6.7 beta3 ?
Hello,
This is Light version no web browser.
Meoboot is very small ,
and you do not have to use if you do not want
Problem when switching between channels. Client mg.... 1.38. PC server newcs. BH 1.6.6. is ok.
From BH 1.6.7. is equal to the problem.
If you have read Board Rules, configuration and/or talk about emu or softcams is FORBIDDEN in this Board.
Hello guys,
just noticed that when on standby the LED displays only the time, can it be changed to date and time?
if it's a config file please let me know where it is.
if its not a conf file how can it be changed ?
Thank you.
Hello guys,
Thank you.
It's a skin coding choice.
Usually Army skins shows only time and Matrix10 skins shows date & time ;)
Thank you for the quick reply,
good to know info but how can i change it ? is it in /usr/share/enigma2/skin.xml ? or somewhere else ? and what is the name of the parameter.
regards
hi
please stages of black hole's image's installation version 1.7.0 full version via usb memory stick, but in a particular (simple) way and complete details for amateurs and for who bought the "vu uno" device recently and still has its own original image on it and it's for the first time that he wants to install an image.
thanks
