Black Hole Vu+ Uno 1.7.1 Server Tuner
I cant install this after 1.7.0?! I have copied it to USB stick, turned off, on, CH- and nothing... I always get MeoBoot screen, and it start booting... Tried 2 different USB sticks, and one HDD all formatted to fat32. Any hint?
If you connected any usb stick on the rear usb port, you can try to remove it before install the new image.
For those who have tried over the net FPGA update for VU uno
Update work now agn.(VU+ server's been awhile down)
Hello
Yesterday I Got my self a VU+ UNO Receiver ! ! :)
Today i Have Flashed New BH 1.7.1 image.
All wend well, after flashing I did a FPGA internet update, all wend well also.
I have installed and mounted my USB Stick and HDD with no issues.
Also DVB-T tuner was recognized successfully.
My Last Setting backup was from Solo BH 1.7.1 image on USB Stick.
I have make a restore to UNO BH 1.7.1 image and all seems fine ! ! !
I have all my services/Mounts/preferences.
Is the Setting Backup compatible for all VU+ Receivers with Same BH Image?
Hi to evrione,
Thank you for the great work,I love the new network tuner.
I have to report a problem with HD channels with S660 usb tuner realy often they don't work and some time appear the waiting logo and the vu+ uno stop to respond.
I have installed the image from scratch without reload any settings or other things.
The best regards.
Hi.
Media Player Deluxe 05 is crashing when i try to open mounted folder(CIFS).
Mounted Folder works fine with Build-in Media Player.
Is this image compatible with latest Kernel 3.1.1 Driver ?
(vuplus-dvb-modules-vuuno-3.1.1-4.4.3-20120126.tar.gz)
Strange mounting behaver.
I have Re-flashed BH 1.7.1 and start from scratch all my VU+ Uno preferences.
All is looking perfect.
I have two network mounts, Video and Music.(CIFS/WinXP)
When I reboot the receiver from Deep-Standby every time,
only one (the first in list) of my net-mounts is mounted.
If I select inactive mound and hit OK on remote and OK again to Reactivate
Receiver Displays the " wait " message for ever..!
I have to switch off/on to reboot.
If I go to mount wizard and deactivate first and delete this mound go back
Select and mound same folder All is OK. ! ? :lamo:
Hello and thanks for this new image.
I have no channel name in VFD Display.
I don't know if i have change something.
Is there an option to put channel name in VFD Display?
Regards.
sorry i am newbie my question is that since some satellites are not avaiable in my area, is it possible to use server tunner virtually or some other way from any friend of me to tune that satellite on my vu?
