Black Hole Vu+ Uno 1.7.4 Parallel Universes
All skins online you can download from image server.
Skins EclipseHD BH 1.7.4 (Black Hole E2)
Skins EclipseHD S BH 1.7.4 (Black Hole E2)
Skins EclipseHD R BH 1.7.4 (Black Hole E2)
Skins EclipseHD E BH 1.7.4 (Black Hole E2)
Skins EclipseHD B BH 1.7.4 (Black Hole E2)
Skins EclipseHD SR BH 1.7.4 (Black Hole E2)
Skins EclipseHD SB BH 1.7.4 (Black Hole E2)
Skins EclipseHD SE BH 1.7.4 (Black Hole E2)
How to set the path for EPG on the usb stick, as once the stick is mounted as /universe there is no such choice in "global settings" of the EPG setup ?
In crossEPG USB Disk 2.0
But you better use another USB stick for picon,epg etc
i mounted my stick as /media/usb and restart
but when i want to format on Usb Format Wizard i have this message
"Sorry, no new usb storage detected. Be sure to follow wizard instructions."
Remove USB and then reboot your box DO NOT PUT THE USB BACK IN
Now start the wizard and put the USB in when instructed.
1.Format USB stick on PC FAT32
2.Start USB Format Wizard with NOT CONNECTED USB STICK
3. USB Format Wizard Red >> CONNECT YOUR USB STICK >> red >> red
4.After format you have to Mount your USB stick with Devices Manager
For universe you have to mount /universe
For Meoboot multiboot / picon etc you have to mount /media/usb
You can use 2 usb sticks one for universe and one for multiboot / picon etc
with different mount points.
It's done, thanks Matrix10 & Artorius
If is possible I'll propose for other release to have the possibility creating 2 partitions on same USB , from BlackHole pannel .
1 ) /dev/usb/ for picon's swap etc or meboot ... ( like this we must try different non blackhole images )
2 ) /universe to have full working 1.7.4
I have tried to create it from linux but no chance , the Vu+ recognize the support as /dev/sda1 but don't see the diferent partition's .
hello,
great image, thanks. it seems faster ! just an error when accessing mediatomb webif (error 500); perhaps incomplete url ?
A little fix to be done on StreamTV player :
When exiting the program, it does not go back to classic TV; we must go in channel list and zap to get sat tv working again.
An other question : Does any one have a IPTV list with channels in French ?
This infact is the thing that is usually missed, I got wrong too, then I read carefully the on-screen instructions (sometimes it just takes so little!) and I had been able to format my Corsair Voyager 16Gb to use as /universe.
All working fine, thx BH TEAM!!!!!!!!!;)
The only incompatibility I can reort so far is the plugin multiquickbutton that changes the remote keymap, disabling red button for red panel. maybe a new release could in the future fix this, assigning red button to red panel. Also I had to reinstall Cool TV Guide as it assigned red button to the guide.
Yes, about this, i'll prepare i pack compatible with 174
Here is the pack with red botton fixed for new BH.
I didn't try it as i prepared pack from office, so be careful.
I suggest to try it not in BH universe so if anything goes wrong you don't have to reflash image, but a big bang is enough.
Let me know if it is ok.
I will test it in Chaos, thanks for your work!!!;)
It´s works!!! Thanks very very much!!!
Hi
Just ordered my vu UNO. Can wait to use this image. Do I have to upgrade firmware on box before I use this image. Is there a new boot loader or will factory shipped on so.
Thanks
