Black Hole Vu+ Uno 1.7.7 HbbTv
We continue in the same situation with the WinTV-USB TDT ministick ... Please do not forget for the next! I still anchored in 1.7.2.
The problem is again the same, this version detects it as as satellite tuner, not as DBV-T :wallbash:
hi,
i made an update from 1.6.7 to 1.7.7
on 1.6.7 i was able to watch diffrent channel on tv and on pc via webinterface..(on the same transponder)
now in 1.7.7 if i zap on webinterface to watch different channel(also same transponder)... the stb zaps also the channel on tv
is this an config thing? and if yes .. can somebody tell me how to change
We are testing new Ministick drivers who solves the problem.
I think they will be released into BH 1.7.8 if all tests are positives.
hello i have a probleme whith this hbb177 whenI look vu uno picture frezze but audio is normal i must be reboot vu uno this probleme is some times only 2 ore
im sorry for my english
If you don't speak English you can post in other languages sections.
Sent from my iPad using Tapatalk
:thanks: THX
Great image from the best team
PS : how to upgrade Hbbtv app ??
:victory:
HBBTV app is already included in the image.
You have to go to a channell where hbbtv is active (E.g.: ZDF on Astra 19.2° east) and press red button, then red button again when a message appears on the right side. So far, no HBBTV service on Hotbird.
:thanks: THX
:victory:
If you mean "howto install upgraded version from Vu+" ... you should wait the release of new BH.
I've tried yesterday to update my Vu+ official image on my Duo and zero packages was detected .... I've reflashed the new image and all is solved.
I thing (about Vu+ official images) the release of one stable image before update that image.
Hello,
Thanks for this new image.
Is it possible, in the next version of blackhole, to change the font color of the markers (change white to red or green for a better visualization) ?
Regards.
Hi everybody
I replace my old receiver with a VU+ Uno and can not install the BH 1.7.7 on it.
The current image is experimental 2011-11-02.
Can anybody help me please?
Hi everybody
First : Upgrade FPGA to version 4.5 see there http://www.vuplus-community.net/board/threads/vu-uno-firmware-upgrade.2955/
Then unzip the image, and put on a usb key (fat32) the folder vuplus (and of course all is inside)
Switch off from rear switch
Insert usb key on front plug
Press and keep pressed the button channel - 'close to usb slot" , switch on with rear switch
wait 3 seconds then release channel- button
when you see "starting" on front display, remove usb key.
