Black Hole Vu+ Uno 1.7.7 rev. B
lorenzo64
Black Hole 1.7.7 rev. B
  • [hbbtv] add playback status.
  • [hbbtv] add volume control.
  • [hbbtv] add connection progress.
  • [hbbtv] fix stream player.
  • [hbbtv] fix status message.
  • [hbbtv] fix cpu load.
  • Delete invalid channel from userbouquet.favourites.tv.
WARNING: This Image is not compatible with the previous skins
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Time Shift
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Red Panel
Black Hole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
  • BlackHole-1.7.7-vuuno_usb.zip
Tulip
Hi :)
I am new to vu uno and i have installed the latest Black Hole 1.7.7 rev. B its working good, but i think i have found one bug, db (signal) meter is totaly off, to me it shows 86~ -> db :eek:
One other thing, if i update to a later build of BH will i all my setting (channels/cams/addons etc.) be lost?
niglou
BH Lover
Hi :)
Each time you flash a new image, every personnal setting is lost.
Make a personnal backup on your hard disk; I would warmly recommand to save also on your PC all your personnal files (use a ftp program)
sakisdvb
BH Lover
Dear Angelofsky1980
Have you implemented the Latest (working) SMSUSB DVB-T Drivers for ReDi Pc100
in this or Black Hole Vu+ Uno 1.7.7 Light (No HbbTv) Image ?
Thank You.
angelofsky1980
BlackHole Driver Specialist
Dear Angelofsky1980
Thank You.
The fixed driver will be included into BH 1.7.8 (if tests ends with success)
