Black Hole Vu+ Uno 1.7.9
Just wanted to post some observations between BH 1.7.8 and 1.7.9 speed, I timed my previous 1.7.8 from switch off on rear panel until picture comes on screen total time took 1 Minute 27 seconds.
I then installed BH 1.7.9 with speed up, I installed exact same plugins i only have 2 Coolmans and Multiquickbutton. I then enabled the Speed up function by disabling all plugins in that menu.
After doing this i again switched power off on rear and switched on again and timed this until picture came on screen total time took 1 Minute 22 Seconds not much of a difference really.
I would have imagined that disabling all of them a speed increase would have been noted in bootup times as well.
I also detect no speed difference in image performance either
Thanks for this new version.
It is faster.
Now from windows to get to the hard drive there are a login and a password.
I put root for login and my password, but without success.
What is wrong ?
Regards.
It is faster.
What is wrong ?
Regards.
By default, there is not a password.
Yes, but if there is one, what is the solution ?
I can access to the flash memory by using the password and WinSCP, but no access to the hard drive.
