Black Hole Vu+ Uno 2.0.2 - Meoboot Revenge
lorenzo64
Black Hole 2.0.2 - Meoboot Revenge
NEW NEW NEW meoboot v2.0:
Meoboot has been completely recoded in order to:
Keep cpu usage to 0%
To be compatible with all OE 2.0 Vu+ images.
You can use meoboot for multiboot, to test any other OE 2 image, for example:
VTI
OpenAAF
OpenPLI
OpenSIF
OpenSPA
OpenViX
and so on...
You can also use meoboot to expand your flash.
For example install the latest Black Hole image in flash,
then install meoboot on a usb stick (i.e 4gb)
Now install again the same Black Hole image in meoboot.
Boot the Black Hole image installed in multiboot and you will have
4gb of flash space.
Black Hole 2.0.2 Changes and updates:
  • remove sctzap dvbtraffic.
  • Add new recipe e2openbhplugins
  • python: add python-beautifulsoup and python-dnspython
  • enigma2 add dependencies for ondemand plugin
  • r8192cu Added some devices to driver:
  • [wlan] added more options to RT5572 driver
  • [autoshutdown] adapted default time patch.
  • Online Feeds Settings: Now listed in alphabetical order
  • Bhsettings adjusted: meoboot device in device panels
  • Change device mount system to UUID=
  • Components/Harddisk: fix bug in hdd inizialization
  • picload: updates and optimizations ...
  • skin.py: make skin compatible with Openpli relative coordinates
  • Update translations: Estonian, Polish, French and Greek
  • [streamplayer] enhanced player and updated stream list.
  • NetworkSetup: added manual-nameserver settings
QUI
bullring
GRAZIE davvero installata sul mio vu+uno installata in meobot e ora o una flash da 500gb incredibile ma vero grazie a tutto lo staff
morphy
all'uscita della versione 2.0.x, se non ricordo male, uno dei vantaggi di queste nuove versioni era che dovevano essere completamente aggiornabili online tramite l'apposita funzione... ma ad oggi nessuna major release è stata rilasciata aggiornabile direttamente da bh, mi piacerebbe conoscerne il motivo...
angelofsky1980
BlackHole Driver Specialist
Gli aggiornamenti online sono all'interno della singola versione (2.0.0 / 2.0.1 / 2.0.2) ma NON tra versioni differenti.
Scelta del coder. Se in un futuro le cose cambieranno, sarete informati.
mikkitto
Ciao a tutti, vorrei segnalare un vecchio problema con la A867, con le nuove immagini dal 200 in poi, adesso ho la 202 su vuuno,credevo che i difetti che aveva prima fossero stati risolti ( dopo qualche ora di funzionamento si va al buio ed altro), ma purtroppo ci sono ancora e per ritornare alla normalità si deve riavviare il dec.
angelofsky1980 è possibile risolvere questo fastidioso difetto, oppure si deve cambiare pennetta?
Grazie della collaborazione
Ciao e alla prossima
alfa_omega
BH Lover
Oltre alla spiegazione già fornita da Angelo, vorrei aggiungere che, grazie al personal backup, ripristinare il tutto in pochi minuti è un gioco da ragazzi....;)
fdgexe
stesso problema anche con avermedia black hd(A835), ed anche con win nova ministick
mikkitto
Come sono collegate le pennette DVB-T al box?
Sarebbe piu appropriato aprire un thread in sezione Drivers DVB-T italiana.
Ciao a tutti, per quanto riguarda i problemi con la A867, ho aperto altro thread per la pennetta A867 in sezione Drivers DVB-T italiana.
Volevo anche segnalare che quando ho aggiornato dalla BH201 alla BH202 e alla 202a non si connetteva a internet, ho dovuto ripristinare i dns primari e secondari sulla rete.
Per il resto va alla grande, ringrazio per la collaborazione
