Black Hole Vu+ Uno 2.0.9.1
with dreambox 800 if I go from my pc and the vu, I can not get in, it may be that when you update the image, put back seguirdad blackhole and that is giving the error?
regards
missing channels
after activation of astra 1n now we are receiving some additional channels in istanbul
in the service search, in some tranponders, services show up during search but they dont appear on the tv service list
this is particularly 12070 GHz frequency
how can be made to see such services
thanks in advance for your help
current imaje is bh 2.0.9.1
paolino, ı am doing service search for all channels not only fta channels
if you perform service scan for mentioned transponder you will see same results
meanwhile ı checked same subject on vti imaje 6.0.6 these channels do not appear on service list
but it can be reached through subservice extension is there a similar option in the bh image
thanks your quick response
If you're on a channel that has a sub service
Long press the green button.
choose sub channel
good afternoon, as I fail enter ftp want to reinstall the image from scratch, but then you can put a old backup?
regards
Hello.
I tested MyTube Player and i can NOT play any video.
I have tried all "know tricks",,,,(Press STOP, Play video again etc.)
Is this an issue for All users ?
Hello.
After intalling image from usb no serious issues using MyTube Player. Probably
was the online update ( faild to be 100% stable) .
