Black Hole Vu+ Uno 2.0.9
Thanx a bunch but I can't download the file. The download is very slow and everytime it stops before finishing. I've tried in different times in the last two days.
Now I tested
I download the file in 35 seconds
true I have a fast internet connection.
But
I still think that something is wrong with your Internet connection.
  • Like
Reactions: DCG
Black Hole 2.0.9
What is new ?
  • New bootlogo by mikark
  • Add option: "Preferred tuner" Available in menu->setup->system->customise (Expert mode). Configure which tuner will be preferred, when more than one tuner is available. If set to 'auto' the system will give priority to the tuner having the lowest number of channels/satellites.
  • Black Hole weather: switch to msn provider to fix bug when town not found and implement auto-langauge.
  • Teletext: Update to the latest tuxtxt version (this fix rai hd televideo too)
  • [hbbtv] updates:
    1. works for compatibility.
    2. enhancement for seek on VOD.
    3. fix setDemension.
    [hbbtv/youtubetv] improvement player to stable.
  • switch to black-hole-aio-grab and fix bug in grab picture with pig
  • hbbtv/browser updated.
    - support seek at ARD Mediatek.
    - fix video playback bugs at Tagesschau.
  • set dvbaudiosink caps to support mpeg 4 profile LC and apply relevant patches.
    dvbapp : append gst-plugins-bad-faad on RDEPENDS.
  • [hbbtv] fix ait handling and transparency.
  • update driver
    20131230
    - Fix dual tuner problem(duo2)
  • [hbbtv] changed ait handle
  • servicemp3 : fix getSubtitleType
  • servicemp3 : fix wrong playing time.
  • [hbbtv] fix zapping delay from ait handling.
  • [hbbtv/youtubetv] fixed volume control bug.
  • [hbbtv] fixed a wrong red-button url bug.
  • [hbbtv] works for compatibility
  • [hbbtv] fix playing live stream after vod stop
  • [hbbtv] fix check vuplus
  • [hbbtv] fix crash restart after installation.
    remove useless initialization.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Thanks BH.
Now I tested
But
Thanx Matrix.. I really don't understand why but still doesn't work. I'm in Italy and I have and optical Fiber DSL @ 30 MB (tested with Speedtest) which works very well and very fast.
I can't obtain the file : the download is very very slow and it disconnects almost every time after a while. If the download finishes (after 2 hours) the file is corrupted.
I'm using Explorer.View attachment 14545
Maybe You use an older Explorer on Windows XP??
and then it is probably a problem.
If you're using an older Explorer try with Google Chrome
that is fast and download without problems.
Thank Matrix; with Chrome the download is even slower.
Maybe is because I use Google DNS?
Maybe you have a problem with that DNS I do not know
But in any case, the problem is with you.
The first day there was a problem with our server, but not now.
Now is very fast.
I tested agn download for 1 a 2 min with 60 MB line
Now is very fast.
The problem with the downloads (and in general with the entire site which is slow) is with the google DNS. I changed the DNS and everything is ok: 1 min to download the file and the site is faster. Very strange : usually the google dns are the fastest. Mah.
Thanx again for yr attention
