Black Hole Vu+ Uno 2.1.0
ایمیچ جدیدش یه دو زاری هم نمی عرضه چه بدرد میخوره تصویر قبلی ایمیچش بهتر بود
I confirm the problem with teletext too.
As soon as one goes on the teletext, not close, to go on a page ... everything is blocked
One solution turn off the box and restart
Thank you for your great work!
It's Not a Solution, behause After restart the Same problem.
And no respond here? What's happened?
Ok there is a workaround to get teletext working for those that need it.
telnet into your box and then type the command
opkg update
and press enter.
Then type the command
opkg --force-overwrite upgrade
and press enter again.
When it has finished, reboot your box and teletext will be working.
I have tested BH210, but finally I decided to stay with BH2091 until next update of BH210. Anyway, BH thank you!
