Black Hole Vu+ Uno 2.1.1
Top image thank you very much
Just did an upgrade myself without problems. Th HDD was detected too (EXT4 formatted).
It is my experience that NTFS is not recommended but still should be detected too.
Obviously it needs to be mounten after the upgrade. In fact the first boot it as detected as meoboot for unknown reason. The second boot allowed me to mount it properly.
View attachment 15542 View attachment 15542 View attachment 15542
From version 2.1.0 (when it became setting AAC downmix) have problems with the sound. sometimes human speech goes like on the back burner and it gets very quiet, a few seconds later everything becomes normal.
a feeling that is transmitted to TV sound in 5.1, though a TV is stereo.
DTS downmix and AAC downmix is enabled.
sorry for my bad english :)
Black Hole 2.1.1​
By Black Hole
  • New skin MX SkyLine SE
  • Add new Crypto systems in OSD: Biss, Bulcrypt, Betacrypt, PowerVu (By Ev0)
  • Add parental control in Bh extra settings panel
  • HbbTV enabled by default for Duo2, Solo2, SoloSE, Ultimo
  • Removed mytube plugin (can be installed from BhSpeedUp)
By Vu+
Kernel:
  • Update Kernel 3.13.5(solo2, duo2, solose)
  • Update Kernel 3.9.6(duo, solo, uno, ultimo)
Drivers:
20140715(duo, solo, duo2, solo2, solose)
20140716(uno, ultimo)
  • - Support SoloSE
  • - Switch to Kernel 3.13.5 (solo2, duo2, solose)
  • - Switch to Kernel 3.9.6 (duo, solo, uno, ultimo)
  • - Fix sound drop in radio channel
  • - Improve PIP (solo2, duo2, solose, Needs E2 update)
  • - Allocate more memory to linux (duo2)
  • - Improve media playback
20140721
  • - Fix vfd problem
Misc:
  • Update r8192cu (4.0.2)
  • Update bridge-utils (1.4 -> 1.5)
  • Set sync PCR at PIP mode.
  • fix duo harddisk detection
  • [hbbtv] fix UI position
  • [hbbtv] upgraded to 'opera-hbbtv_0.2.bb'
  • disabled copy libs to sysroot
  • [hbbtv] reduce CPU usage
  • [hbbtv] fix ipc protocol
  • [hbbtv] fix flickering some channel.
  • support seeking the recorded video
  • lcd4linux: update to 4.1-r2
WARNING! DO NOT USE PERSONAL BACKUP FROM PREVIOUS BLACK HOLE IMAGES, AS THIS WILL MIX KERNELS AND LIBS CAUSING MANY MALFUNCTIONS.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
thanks
I cannot see the attachments. It gives me an error!
What type of HDD are you using?
I presume you did not use a Restore from a previous release? This version uses BH5 format for backup/restore which is apparently not compatible with previous releases. I did a full native install myself. Just used DreamBoxEdit to restore my bouquets, which worked fine. Still a lot of work to get all my personal stuff and preferences back to work as I was used to.
On an UNO you need also to avoid flash memeory overload. I am using Parallel Universes using a USB-drive mounted to UNIVERSES to avoid that. This is the only way to get amonst others HBBTV working with version-2 releases.
HI AGAIN
I'm usinh ATA (OCZ-ADILITY3) 120GB SSD
JUST IN THE NEW VERSION 2.1.1 CAN'T DTECTED CAN'T USE IT OR MOUNTED ,,,,,!!!!
HI AGAIN
Never used an SSD with my UNO but obviously is a nice setup.
I have read somewhere that support for HDD above 2 TB was added. I don't now if that was with this release?
SSD's are a bit picky regarding drivers and the various SATA modes these support. I am afraid somebody else needs to help you. Good to know is if a common HDD works fine?
Does not work "AVerMedia AVerTV Volar Green HD - USB TV Turner DBV-T" on image 2.1.1.
In image 2.1.0, 2.1.0.1 and earlier works fine.
Thanks!
