Black Hole Vu+ Uno 2.1.5
I found some delta that might have something to do with USB DVB-T not working.
On BH 2.1.0 I get
root@vuuno:~# dmesg | grep dvb
dvb_bcm7413: module license 'Proprietary' taints kernel.
dvb-usb: found a 'Artec T14 - USB2.0 DVB-T' in cold state, will try to load a firmware
dvb-usb: downloading firmware from file 'dvb-usb-dibusb-6.0.0.8.fw'
usbcore: registered new interface driver dvb_usb_dibusb_mc
dvb-usb: generic DVB-USB module successfully deinitialized and disconnected.
dvb-usb: found a 'Artec T14 - USB2.0 DVB-T' in warm state.
dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
dvb-usb: schedule remote query interval to 150 msecs.
dvb-usb: Artec T14 - USB2.0 DVB-T successfully initialized and connected.​
but on BH 2.1.5 I get
BRCM brcm_dvb0: DVB: registering adapter 0 frontend 0 (Vuplus FE)...
c327bff41e580916e7d0af2cf412d419a8bc21cb rename dvb_usb_v2 related functions
e0d2c74dd664342588c5af3bdee78040f9f8e6db dvb_usbv2: rename function to bh_*
epc : e12f4428 usb_urb_exit+0x768/0xf0 [dvb_usb]
ra : e12f4430 usb_urb_exit+0x770/0xf0 [dvb_usb]
Modules linked in: ext2 dvb_usb_dibusb_mc(O) dvb_usb_dibusb_common(O) dib3000mc(O) dibx000_common(O) dvb_usb(O) bh_dvb_core(O) bh_rc_core(O) fpga_directc(PO) brcmfb(O) dvb_bcm7413(PO) procmk(O) ipv6
[<e1314770>] dibusb_dib3000mc_frontend_attach+0x64/0x1c0 [dvb_usb_dibusb_common]
[<e12f2198>] dvb_usb_adapter_frontend_init+0xe0/0x1cc [dvb_usb]
[<e12f0000>] dvb_usb_get_hexline+0x0/0x12c [dvb_usb]
[<e12f0d18>] dvb_usb_device_init+0x594/0x87c [dvb_usb]
[<e131d034>] dibusb_mc_probe+0x34/0x40 [dvb_usb_dibusb_mc]​
Also for lsmod there are some deltas. On BH 2.1.0 there are lines that are missing on BH 2.1.5
fuse 75068 0
mt2060 4022 1​
What else could I check for find a solution?
Erkki
We are working on it.
already there was coherence upnp server in pseed up panel and we can stream vu dvb on windows phone mobile but in new version i cant see this.it was the only way to stream dvb on windows phone mobile.
Thanks a lot
there are no problems with the image but with servers, the epg isn't working properly.
the skin is fairly new and some plugins can't integrate into it
Vu+ is lucky because you're here
yes there seems to be a problem with the epg, i got the rytec epg fix from the other thread it worked fine but when i restarted my box, the epg displays only current and next event. when i check the database info it says last update is on the 22nd i just downloaded this morning
thank you BlackHole team .
how i can change blue screen to red color ?
On your remote control press:
<MENU> <ADDONS> <ADDONS DOWNLOAD MANAGER> <BLACKHOLE IMAGE BOOTLOGO> ---> scroll down until you found this bootlogo: Milkark Bootlogos BH01 Red, download and install, restart enigma2.
Thanks so much you teaching me something can not understand for a long time
Hi guys. Today I updated BH from 2.09 to 2.1.5 and rescanned satellites. Now I have strange behaviour from dreamboxedit, when I zap to channels I get error message - "zap command failed" (in the log: "The ZAP command did not receive the normal 0 returncode from the Dreambox."). Channel is switched at the end, but with delay of few seconds. Tested also dreamset with same result. Do you experience same behaviour? Channels which I have in my bouquets are working without this error, those only in satellites list suffer with this problem.
Hi, thanks for the new version, I have updated from 2.0.9 version and now I have problems with tdt tuner. When I have one channel for several minutos or a few hours the screen go to black and I see in a few seconds a message error. Then the only solution is restart my Vu plus Uno.
The message error is in spanish:
Mensaje (4)
¡No hay datos en el transpondedor!
(Tiempo cumplido leyendo el PAT)
I think in english the message can be similar to this:
Message (4)
No data on the transponder!
(Time up reading PAT)
The USB tuner is AvermMedia AVerTV Volar Green HD and the vu plus recognize like A835 (DVB-T) model.
Can anyone tell me what is the problem and how to solve it?
Regards
Nice interface BUT...
1. cant choose the ***** that is installed
2. "My tube player" doesnt show the text that is written when shearching
3. YouTube application is very slow for VU+ UNO
Hope you fix these bugs, at least the first two...
Thanks
1. cant choose the c c c a m that is installed
Thanks
Thanks
Already banned ....
