Black Hole Vu+ Uno v.2.0.8
Hi
Friends came to see the film, which is a plug-in subtitle display as well thanks to the introduction of
Me too am experiencing issues on playback video: sometimes no audio, sometimes no video but audio, sometimes frame freezes while audio goes on.
My feeling: this new firmware is too demanding for Vu+Uno type of hardware.
Am I alone with this feeling ?
Am I alone with these issues ?
Thanks
Thanks
In my vu+ UNO with 2.0.8.1 no such problems....Everything works perfectly.
My problem Vu+ Uno Black Hole 2.0.8.1 neotion conax modul no open channel,there is a solution?!Other indoor unit work all that well.
It's not clear: you have a Conax CI module with the corresponding card and the channel doesen't clear?
The rights on the card are correctly detected? Your module is correctly detected? Have you assigned, in last try, to assign the CAID to the corresponding CI slot? Have you tried with the CI module into the other slot? Have you tried the same module+card into another CI module? Your module is CI+?
I've tried everything. :-(
CI Module and card see the device.
Black Hole 2.0.4 It worked when I bought it.
