Black Hole Vu+ Zero 2.1.5
hi
thank you again for bh
I have no problem installing tsmedia
just that if I want to watch something I have not the full screen just 1/4 of the screen
all upper left corner of the screen
you had a solution
thank you
hackeurs50
Solution is to use old skin
Or even better users can ask the plugin author to support 1920 x 1080 format skins
which is much better for the fonts/letters and graphics
Any solution to fix it???
I tried some drivers manually and still not working
Why in other images run playtv tuner and in bh no?
Because BH uses latest DVB USB drivers and other images uses the kernel stock drivers.
We have made this choice a lot of time ago to support more devices than standard drivers.
We are working on this issue and takes 100% of our free time.
thank you very much for answering. while, I can fit it with some specific driver tuner that works with this image? (What driver? How?)
O better to wait?
hi all, after upgrading to 2.1.5 from 2.1.4 my dvb-t usb tuner is not recognized......"dummy tuner". It worked perfectly on 2.1.4.
The model is a nova-T.
Thanks for help and thanks for great work!
We are working on this issue. Read my previous two posts in this discussion.
I got a problem with HDMI CEC. It's not working properly with 2.1.5 version anymore.
If i put my vu+ tuner to standby it's turning off tv and audio receiver to but receiver is not turning off anymore (display say's only word MUTING).
Any hope to fix this problem?
Hi guys
Just got a vu+ zero, i am tryinf to go into black hole speed up but it just freezes. i got the moving icon in the left hand corner but nothing else happens until i restart the box
Ihave tried bot 2.1.4 and 2.1.5 still the same problem
also im trying to install autoboquest and it says cant connect to host
i have doing thre cfe upgrade. still no joy
i have been into network settings and it says all is ok. i can even transfer files from pc to zero
any help appreciated
We had problems with our server last night
Server is restarted.
Now the site is back on line.
But it seems to , Speed UP does not work.
We should wait for the solution of the problem.
ok will this affect installing some addons like lrazier autoboquet?
as this is not installing too? or is this a separate issue?
when i try to install it it says
execution in progress:
wget: cant't connect to remote host (209.236.115.82): connection timed out
