Black Hole Vu+ Zero 2.1.7
Black Hole 2.1.7 MultiBoot
WHAT IS NEW
    • New switch from MeoBoot to OpenMultiBoot to use different kernels and drivers for each installed image.
    • New skin MX i6p By Matrix10
    • Vu+ drivers 20150623
      - Fix tuning problem(AVL6211, duo2, solose)
      - Improve vtuner(satip support)
      - Fix scrambling bit in recording
      - Improve transcoding
    • Xbmc Support 576/720/1080 resolution
    • Updated Vuplus-Blindscan
    • Updated HbbTv
    • Updated WebManual
    • Added Sat>Ip Client
    • Included UiPositionSetup
    • Removed MeoBoot
    • Added OpenMultiBoot
    • Updated Lcd4Linux
    • Updated MediaTree (usb tuners drivers)
    • Fixed random socket error
    • [ScanSetup] fixed error on complete scan with T2 tuners
    • [ScanSetup] fixed TT3L10 automatic scan problem
    • [unicable] support JESS(EN50607) and update unicable.xml
    • AnimationSetup: set default to animations disabled
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UPnP Server Mediatomb
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
DISCLAIMER
LICENSE (TERM OF USE)
Thank you
WHAT IS NEW
    • Updated HbbTv
    • Updated WebManual
    • Removed MeoBoot
    • Updated Lcd4Linux
Is XBMC Launcher Compatible for VU+ZERO . ???? IF YES HOW TO INSTALL ON MY BOX ?????
VERY VERY NICE IMAGE .
THANK YOU ...
THANK YOU ...
Severall times answered to the same question.
XBMC is only for lastest generation STBS ( excluding ZERO ), i.e. DUO2, SOLO2 and SOLO Se.
Best regards
I heave a problem with this image with IPTV streaming, before i heave OpenBlack Hole image and my IPTV LINKS played very well, but with this image my LINKS not streaming, i try on other VU+ZERO box with OpenBlackHole image ,and with VLC and the links played very Well, I Like this image and i don't want to change . Heave some way to playing IPTV Links ?????
Thank You
